Question about MSI MEGA Stick I (128 MB) MP3 Player
MSI Mega stick
My mp3 stick wouldnt turn it on, it was working fine and when i connect to PC,still it can connect to pc but i just cant turn it on. please help
  • 5 Answers
SOURCE: no file
The "NO FILE" message on the LCD Screen means you don't have any songs on the Drive. You need to plug the device into your computer and transfer songs to the device.
Posted on Jan 23, 2007
0 characters
1 Points
Can't format
Preformat : By Fix-shad0w
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Jun 15, 2010 | MSI MEGA Stick I (128 MB) MP3 Player
My gpx mp3 works fine and turns on when it is plugged into my pc, but when I take it out (even fully charged) I cant get it to turn on anymore.......... any suggestions??
I think maybe your battery is relying on the USB connection for most of its power while connected to
your PC, but doesn't really hold a charge, and needs to be replaced.
Apr 17, 2009 | GPX MW-3847 MP3 Player
PC won't recognise player
I need audiophase k1000 mp3 player drivers
Feb 23, 2008 | MSI MEGA Stick 511 (512 MB) MP3 Player
Msi megastick 1 error
Hi, The MSI Mega Stick normally comes with a utility/installer CD. On running setup, there is a software which would allow you to download the firmware to the Stick. Reinstalling or updating the firmware should reactivate your MP3 player. If the CD is not available, you can try download the same from the MSI site, the file name is Instructions are also posted on the site > Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 02, 2007 | MSI MEGA Stick I (128 MB) MP3 Player
I Cant start,I cant connect to my pc
hi friend hi me too had the same problem, but for me it was not working merely more than four months and today(2007 june 12) finally i tried it with my PC. What i did i connected it with my PC with locking the device (using the hold button in the opp side of the menu button it has to show the orange face once u pushed it off)more than one hour with the screen of "San disk Initilizing", after an hour i tried with san disk firmware and many tools nothing to do. Finally what i did "realy its amazing to u all,even u people cant beleive it, but it is true", simply i pressed the menu button twice or thrice and no result then i had beat the device it has been worked fine its showned the screen as USB connected by MSC.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
Cannot format my MP3 player
I'd suggest to reformat it using FAT filesystem. In linux, type mkdosfs -F32 /dev/sdb1 (or however your device is named)
Oct 11, 2006 | MSI MEGA Stick 511 (512 MB) MP3 Player
Can't turn on the Player!!!
what i did when mine wouldnt turn on is unscrew the back and take the battery out wait a few seconds put it back on and it works fine
Jul 31, 2006 | SanDisk Sansa e250 MP3 Player
Same problem with MP3
try to connect it other computer,if it works normal on other pc then its ok, or you can also try to use other usb port in your pc, and if this doesnt solve your problem, i think you should replace it.
Jul 30, 2006 | Creative Labs MuVo V200 MP3 Player
Player Problem
hi home page of your player: good luck
Mar 26, 2006 | MSI MEGA Player 515 MP3 Player
MSI MEGA Stick I (128 MB) MP3 Player Logo
26 people viewed this question
Top MSI MP3 & Digital Media Players Experts
Are you a MSI MP3 and Digital Media Player Expert? Answer questions, earn points and help others
