Question about LG Televison & Video
LG Rear Projection TV Model RT-62NA31RB
The picture disappeared suddenly! Several technicians have tried to repair it and failed. Now there is a feint picture but there are thin, red and green lines, in pairs going across the screen, in an oval shape. Sound seems to be ok. I live in Beira, Mozambique, where technology hardly exists! Please advise - thanks in advance. Kind regards, Perry
5 Suggested Answers
SOURCE: Curved red lines across screen
hi there, i had the exact same problem as you and this is how we solved it. Instead of replacing the convergence IC's as suggested above, which requires soldering and de-soldering, which could damage your board (this happeend to us). Order online part # SSB-5068A. This is the ENTIRE convergence board with new IC's. Cost you about $140 (from vance baldwin.com) but is a lot less hassle than you trying to soldering/desoldering parts. Only thing is, next to the 2 large heat sinks, there is this large silver component that you need to unscrew from your old board, and unplug and attach to your new board. We tok the new board..hooked up all the wires..and voila, no more convergence issues.
Posted on Jul 13, 2007
  • 70 Answers
SOURCE: lg rt 56nz23rb
Hi there.
Replace the stk convergence ics and also the 3.9 0hm fusible resistors.
Posted on Oct 15, 2008
  • 157 Answers
SOURCE: thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Posted on Sep 02, 2009
Testimonial: "good suggestion."
  • 35 Answers
SOURCE: the blue is oval shape drawn upward on the bottom
YOU HAVE CONVERGENCE PROBLEM. you need to have an electronic technition replace convergence ics and related resistors and pico fuse. J.D.W.
Posted on Jun 25, 2010
Testimonial: "I REPLACED THE IC'S IT WORKS FINE. THANKS"
I have a 60 Inch LG Plasma TV Model Number 60PV400-UB I have sound, Remote chances channels and can tell volume is still working but have no picture.. Just Black Screen
The most likely case is that the 'backlight' has failed.
If you turn-off all the lights at night, you can generally see the feint picture generated by the screen. If you can see the picture it means the backlight has failed. You might be able to get the backlight replaced.
If you can't see the feint images, either the hardware to generate the images has failed or the LCD screen itself has failed.
Unless it's under some kind of warranty you'd need to get a repair quote for it. But if the LCD screen itself has failed, it'll essentially be uneconomic to repair.
Best of luck
Mar 08, 2018 | LG Televison & Video
How do lg,rt-62na31rb 'pogection tv outo no menuval convergance on remote controller
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Convergecne procedure to PTVs are given. Search the site by type in this keyward "Convergence" in the "Search box at the top right of the Homepage".
Oct 14, 2016 | Televison & Video
My lg projection tv model rt 62na31rb curved color problems
you need to adjust the convergence setting on the tv.
http://www.youtube.com/watch?v=esk4nYZKFcg
enjoy the groovy music on the video
Oct 08, 2014 | Televison & Video
Lg rt 56nz23rbLG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no picture and than switches off by going into stand by position.The horizontal and vertical outputs...
Thus problem sounds like you have some failed capacitors on the power supply circuitry. I have had this problem on an older TV and it was solved by replacing the popped caps. Do not try this repair yourself, unless you are confident you can do so safely! Also make sure that you unplug everything before poking around inside!
Mar 19, 2014 | Televison & Video
I see 3 picture in my tv
This television needs to be repaired by a qualified service center or replaced. There is no adjustment that can be made at home to fix the problem you have described.
Oct 24, 2008 | Samsung PCL541R 54" Rear Projection...
Lg rt 56nz23rb
Hi there.
Sep 20, 2008 | LG RU-52SZ51D 52" Rear Projection...
I own a LG rear projection tv model number RT - 44NZ31RB and for some reason refuses to turn on. Worked fine and then all of a sudden stopped. Standby light comes on and then a small noise can be heard...
had the same problem as described, exactly. happend after 13 months of use.
I had the power suply replaced and it works perfectly since then.
Jun 30, 2008 | Televison & Video
THE COLORS ARE SEPARATED (RED, YELLOW & BLUE ETC.)AND THE PICTURE IS NOT CLEAR. THE PICTURE IS BOWING AT THE TOP AND BOTTOM OF SCREEN. PLEASE ADVISE.
You need new convergence ICs this is a common problem on all projection TVs. Please post the model number of your set and I will post a link where you can order the new ICs and recieve free step by step instructions with pictures on how to do the repair yourself.
Mar 31, 2008 | Televison & Video
The HD capabilities seem to have disappeared?
no idea on your exact problem yet but LG the manufacture of this unit had a recall on this model for several issues and they are paying for out of warranty repairs for certain problems you may want to call them and see if you can get some help from the manufacture.
Mar 08, 2008 | Zenith E44W46LCD 44" Rear Projection...
LG Rear Projection Television Model RT-56NZ23RB - Fault
Check your horizontal output and regulators also vertcal output.You have a deflection problem either Horizontal or vertical outputs or one of the regulators are faulty. Let me know if you require more assistance.
Feb 02, 2008 | Televison & Video
Televison & Video Logo
117 people viewed this question
Computer Repairing
Computer Repairing
