Question about Samsung SPH-a740
Phone got wet and now unable to power on.
Phone got wet unable to power on. I took battery off and connect the charger and it stated, "battery not connected powering off.
  • Richie12 Feb 06, 2008
    phone was working fine, then randomly powered off. started charging thinking battery ran out, but says battery is not connected. what do i do?
Most likely the water renered it useless for a while. Try drying it out more, DO NOT HEAT IT, or spray it at all. If you have a techy friend who would give it a shot, they could open up the phone and try cleaning away the corrosion that that water damage caused with contact spray or rubbing alchohol and a soft bristle toothbursh.
Posted on May 15, 2008
Why does my Motorola Admiral not turn on automatically when it's plugged into a charger?
it's not to worry about your phone when your phone does not start automatic because in the only region off your better dead. you just live your phone into a charge sometimes after you can see your phone is automatic restart
May 17, 2017 | Cell Phones
LG NEON GW370 CELL PHONE WON'T TURN ON
Check the battery first, connect into charger. If phone was wet, you need to clean it in isopropanol. Or just dry for few days (you can use hair dryer) carefull to dont overheat phone. Even if you think phone is dry it can be still wet. Check if connectors from charger are not dirty. (Check charger, and battery) best way is to borrow battery from friends phone
Oct 21, 2011 | LG Neon GT365 Cell Phone
I need to find a manual to know how to change the batteries in this phone
First of all, it will be advice able for you to write in the name of the type of phone you want to change the batteries. If it is clearly stated, I will so happy to be f service to you. Please kindly state the type of phone you want to change the batteries. By stating the name of the phone and the model for example nokia E71 or samsung corby etc.
Also before replacing a battery of a phone, be sure to have tested other components that are related to the power before concluding it is the battery that needs replacements. Components to also check are the charger and the phones connection port by trying out other devices on them, like trying the charger on another device and trying another charger on the phone so as to know if the problem is from the charger or the connection ports respectively.
Would be happy to be of service to you. So please state the type of phone and model number.
Hope this was helpful. Thanks for using fixya.
Jan 26, 2011 | Cell Phones
Cell phone took a ****
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Apr 15, 2010 | Motorola Mobility Clutch i465 Cell Phone
Battery won't charge
Please get it serviced through Service Center.Battery may be dead .Battery gets short circuited when wet .
Oct 28, 2017 | Samsung Eternity Cell Phone
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
Samsung sgh-i607 got wet
mi blackjack got wet and it does turn on and it says that i have a text msg and that i have 3 missed calls buy the entire keyboard is not working,, what shoul i do?
Jul 08, 2009 | Samsung Blackjack SGH I607 Car Charger
Unable to charge
There could be corrosion on the charger, or the connection on the phone? If so, remove the battery and clean them both with a toothbrush and Isopropyl Alcohol. The phone may have gotten wet? Check behind the battery, there is a water indicator. Its normally white, if its gotten wet, it will be red. Best of Luck.
Sep 14, 2007 | Motorola Mobility RAZR V3
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
My phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
Dec 28, 2006 | Motorola Mobility RAZR V3
Samsung SPH-a740 Logo
150 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
