Question about LG 37LC7D 37 in. LCD HDTV
Viewing area is cut off at sides
I recently noticed when graphics display on screen, the edges are not visible (or cut off) or outside the viewing area. I have tried all the ratio options but none of them allow the picture to be completely included.
  • Anonymous Nov 16, 2008
    I have the exact same problem with this tv although I feel it may have something to do with the cable box i'm using.
  • le_grand_man Dec 06, 2008
    I've got the same problem. When I connect my laptop on the tv, I can'T see all the screen.
    The display of my monitor seem to have a translation to the right and up.
It's not your tv. It's your cable box setting. Go into settings on your cable remote and set picture size to normal and not zoom or any other setting. Also make sure your picture format is set to 16:9 on your tv. If you cannot figure how to change picture size on your cable box, contact your cable provider. Good Luck.
Posted on Nov 16, 2008
I currently have a toshiba l500 and the screen has shrunk only on the right hand side about an inch and has streched vertically past the viewing area. Does anyone know how to fix this problem. Thanks
Open Device Manager, Display adapter, Uninstall Graphics adapter, and drivers if asked. Reboot the Toshiba, allow the software to install the generic driver, Run windows and toshiba updates, Update graphics adapter. post results.
Jan 27, 2013 | Toshiba Satellite L500 Series Notebook
Not showing entire image on screen
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
Feb 18, 2008 | Sharp XR-10X Multimedia Projector
PC monitor driver for Sony KDL52xbr2 rgb connector.
install original Graphics driver. its only display settings in your pc.
May 30, 2009 | Sony BRAVIA KDL52XBR2 Television
My screen appears horizontally expanded
If your monitor is crt type, on its menu control, goto menu setting look for something that will adjust horizontal width. Or set the adjustment on Display setting in windows.
Apr 10, 2009 | Computers & Internet
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
New Samsung 1080p TV not displaying Full 1080 from PS3 Blu Ray movies
Hi hsaucier,
Although you have a wide-screen television, it is possible the video you are viewing was recorded in an even wider format. The bars should be smaller than if you were viewing the same DVD on a TV with a 4:3 aspect ratio, but will likely not disappear unless you view the DVD at a zoom setting. Many movies are shown in theaters at a wider ratio than 16:9, and the Blu-Ray disc has probably retained the entire picture rather than cropping it to fit your screen.
I recommend trying different viewing options that zoom in slightly. Be aware that this may cut off part of the picture from the left and right sides, but depending on your personal preference, you may not notice anything missing.
Thank you,
Go Ahead. Use Us.
Jun 15, 2008 | Televison & Video
Vertical Lines / Color Differences at edge of Analog vs HD Picture
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
LG 37LC7D 37 in. LCD HDTV Logo
604 people viewed this question
Computer Repairing
Computer Repairing
