Question about Nintendo Wii Console
2 discs stuck how to open
How do open top case? There are screws that I have never seen. Three notches?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Is the top case were you plug in nintendo gamecube controllors? If is....you don't need to unscrew anything..it should just pop off!
Posted on Nov 26, 2008
Tip
PS3 Won't accept discs - Here is the fix!
This tip is for people who have already disassembled their Play Station 3 console and tried to replace the laser in the Blu ray optical drive.
If you replace the laser and then reassemble the Blu ray optical drive and the drive will no longer accept discs (like there is something blocking the disc) follow these steps to resolve.
(NOTE: if your PS3 is not accepting discs because the disc just won't push in, not like there is something solid blocking the drive, or your drive is making "grinding noises" refer to this tip: http://www.fixya.com/support/r4321102-bluray_drive_ps3_makes_grinding_noise )
Remove the metal casing of the Blu ray optical if you have not already done so. This requires removing the three black screws and the two silver screws on the bottom of the Blu ray optical drive.
With the metal casing removed, locate the 5 black screws on the top of the Blu ray optical drive to remove. There are two on either side and one at the back in the middle.
Keep the drive together for now (do not take the top off) and reattach to your Play Sation 3 console.
Turn on your PS3 and wait for it to power up.
Now, take the top of the Blu ray optical drive by “unfolding it” so the top of the drive rests on the PS3 power supply.
With the top off, hit the Eject button on the front of your PS3.
The drive gears should “pop” back into place.
Turn off your PS3 and reassemble the Blu ray drive. You should test your Blu ray drive first before reassembling the whole PS3.
on May 13, 2010 | Video Game Consoles & Games
Tip
Bluray drive on PS3 does not accept discs after disassembling
on Feb 16, 2010 | Video Game Consoles & Games
Dog pissed onit how do i open case to clean!!!?!?!?!?!
ha ha unlucky m8 these are the tools you will need and the steps you will have to take to open ur ps3 :)
Tools Needed
  • 1 Small Socket Wrench
  • ¼ inch Socket
  • (1) T-10 Star Tip Point – that fits ¼ inch Socket
  • Philips Screw Driver
How to Do It:
  1. Remove the Warranty Sticker
  2. Behind the Warranty Sticker you’ll find a star tip screw. So set up your socket wrench with the star tip point and unscrew the screw.
  3. Remove the Screw and Remove the Plastic PS3 Top Plate
  4. Now you’re looking at the console you’ll have to remove (7) Screws, Notice (6) of them will be long and 1 will be shorter than the others
  5. Remove all the screws, once that’s finished start at the back of the console and pop the unit open with your hands.
  6. Now you should have the console open and you’ll seen the disc drive and power supply
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Tip
How to Take Apart Your Xbox 360?
1. Insert your index and middle finger into the memory slot holes, place your thumbs on the bottom of the Xbox (for leverage), and pull the face plate off with a steady force. It should come right off. 2. Break the Microsoft seal off. (Note that this will void your warranty.) 3. Now, flip the Xbox on its side and take a close look at the holes located on the top and bottom of each side. If you look closely, you can see that some of the holes are filled in. This is because the filled-in holes are keeping the grey plastic pieces on the top and bottom of the Xbox in place. 4. To remove the top and bottom grey pieces, use a small pointed object. Locate a grey plastic tab by peering into the holes, then use your pointed object to carefully push down and lever out the grey top/bottom cover. Both pieces have three tabs/clips per side, with a total of six per piece. To remove the top grey piece, you will have to remove the rubber pad. This is the only rubber pad you will have to remove. 5. With the grey pieces removed, take a close look at the back side of the Xbox. On the right and left side there are small notches that will require closer inspection. You again will need a small screw driver or narrow probe. 6. Using the probe, start on the left side (near power plug socket) and push the catch a bit into the Xbox until it clicks, then use a screw driver to keep the two sides apart. Once the left side is done, start on the right side and do the same thing to the rest of the catches. 7. Once they are all separated, the bottom of the Xbox will lift away. At this point slide it around to the front side and undo the four catches, keeping the case together. 8. Now grab your Torx driver set. You can use a T10 and T8 to do the job. You do not need a T12. 9. Unscrew the six T10 black screws, then use the T10 to unscrew all the silver screws. Finally, unscrew the black screws with your T8 driver . 10. Carefully flip the Xbox back over and remove the DVD button arm assembly to keep it out of your way. You just need to pry it off the black plastic guide. 11. Next, remove the top cover. Watch the DVD button latch. 12. Disconnect the SATA connector and power connector from the DVD drive and lift it out of the case. 13. To remove the white plastic air guide, locate the notch on the top outward side, insert your probe/small screw driver, and leverage the air guide out. It should lift straight out very smoothly. 14. Disconnect the power for the cooling fans. Now, use your probe/screw driver to pry the fan catches out from the metal guard. This will allow you to remove the fan device from the Xbox case. 15. Look at the front of the Xbox on the RF module, and remove the white plastic power button. It is held in place by a clip on the top and bottom. 16. Remove the three screws from the front circuit board (RF module). 17. Once the screws are removed, you will be able to slide the front circuit board off the Xbox with a slight pull. Notice that it is connected on the lower left side. You should now be able to pull the entire circuit board right out of the case with relative ease. Be careful not to touch any exposed circuits. 18. The next step is to carefully lift the motherboard out of the Xbox case. With the motherboard removed, flip it over and locate the two X connectors on the bottom. These are what hold the heat sinks on the processor. You can remove this; just be careful. It takes a little bit of force, which could destroy your Xbox if not applied properly.
on Jul 22, 2007 | Microsoft Xbox 360 Console
Disc stuck in wii console
Your Wii will require Warranty service from Ninteno. However, if you send your unit chances are they won't return the disc.
How to open your wii – http://wiki-scene.com/Wii_disassembly
Once you get to – 'Remove 4 DVD drive screws' Dont do that, just take the 5 screw off the top of the Drive, and the drive will split into 2 and you can easily remove your disc. Reassemble and contact Nintendo for Warranty service.
Dec 15, 2008 | Nintendo Wii Console
Xbox 360 freezes with HDD
Your X box needs to clean most important the fan,below an instruction how to open...
DON'T FORGET TO RATE;
Aug 17, 2008 | Microsoft Xbox 360 Console
Playstation 2 problems
The PS2 Works fine right correct?? If it does and you want to fix the Laser do the following :
Step 1 Turn off the PS2 if on.
Step 2 make the PS2 lie down on its back where the PS2 logo is not seen.
Step 3 Take off the Rubber Squares which are located from all 4 corners and take out the screws using a screw driver.
Step 4 Take off the lid of the PS2 after the screws are taken out.
Step 5 near the light of the PS2 were it shows the Green and blue light is a box where the PS2 disc runs.
Step 6 screw the top of the box and you should see a disc if not taken out and underneath the disc is the lens use alcohol and gently wipe the lens with a Q-Tip after doing so put the lid out of box back on and open the disc drive and put a game in it should work or just get a new PS2 Slim.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
Won't play discs.
Hi Crashley41,
You Laser must be burned out. Since it doesn't play any discs, I believe you have a melted laser. In this case, your disc should not spin either. You need a new laser. Click on "Repair Directory" at the bottom of this screen. Then click on "Video Game consoles" in the next Screen. Pick a good Repair shop dedicated to Playstations. You can probably get a good deal on getting your Playstation working top notch again. Good Luck
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Nintendo Wii Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
