Question about Acer Aspire 5610-4648 Notebook
USB device conflict by using two printers
I am using sony vaio latest laptop. first i did install printer hp1000 and this printer successfully installed but when i install another printer hp1020 i found some driver problem and later this printer also install successfully. afterthat when again i plug in printer hp1000 my laptop showing that printer is ready to print but unable to doing print through said printer. some one told me that your laptop USB device is not working problem delete those devices by using safemode of window and install them again.
Please let me know is that solution is correct for windows vista or having another solution for that.....
  • Acer Master
  • 4,338 Answers
Yes, if that does not work, do the following:
Go into the properties of each printer and the on the port tab, make sure that the printers are set on different USB ports.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 05, 2008
How do I remove the yellow ! from my Vaio laptop icon in devices and printers
Have you tried connecting to a different computer? The problem may be a mechanical breakdown of the printer itself.
May 15, 2014 | Sony VAIO Computers & Internet
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
I want to purchase a laptop printer Canon bjc 80 will it connect to my vaio via the usb or whatever the 15 pin plug is on the left hand side
According to the specs this printer uses IEEE 1284 connection which is infrared. So you would have to have an infrared receiver/transceiver on your laptop or purchase and install one. In other words this printer does not connect directly to your USB port or your Paralell Port.
Mar 27, 2010 | Sony VAIO PCG-K35 Notebook
I have the installation disc and connected with the USB cable. Shows the printer installed and set as my default printer, but will not print. Are Dell printers not compatible with Sony VAIO laptops?
there is no compatibility problem.. u just need to uninstall the drivers and go to support.dell.com to download and install the latest drivers for ur printer model.
Dec 30, 2009 | Dell 922 All-In-One InkJet Printer
My sony wont recognise a usb device
Depending on the type of device, you may need to install drivers prior to plugging the device into the computer. You may also try:
1. using a different port
2. try a different device to check if it might be a problem with usb port.
3. remove any other usb devices first. one might be interfering like a mouse or keyboard.
4 go to the sony website and download the latest drivers for your system.
Nov 11, 2009 | Sony VAIO PCG-K23 Notebook
Sony vaio audio driver problem
if not anything open the system and check the connections sounds like you have hit on everything else besides that
Jul 21, 2009 | Sony VAIO VGN-FS840/W Notebook
Cannot install my hp900inkjet printer to my sony vaio vgn-fw300
dear sir what is the Operating system that you installed is it windows or other OS : laptop and what is the connection that you use is it USB or parallel thanks
Jun 21, 2009 | HP DesignJet 9000 InkJet Printer
My laptop doesnt detect USB Pen drives (sony vaio VGN-FJ 270)
Go to start->control panel->system->hardware->device manager. Expand Universal Serial Bus controllers. Right click on every USB root hub and select uninstall option. They will be reinstalled on next restart.
After that plug USB pen drive to usb port - go to start->control panel->system->hardware->device manager. Click Universal Serial Bus controllers then click on Action tab (the one at the top of Device manager window and select scan for hardware changes.
If that will not solve the issue try different USB port.
Make sure you have latest service pack installed so Windows would install proper drivers for the device.
Let me know if this is not solved
May 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
I lose my internet connection when I connect HP Photosmart C4400
I am assuming that you also connect your printer via USB cable. If so, it is possible that there is a conflict of your printer and wireless card in your USB settings.
To check if there are any conflicts, click on "system" in your control panel, select "device manager" , and look for your wireless card, printer and usb ports in the list of devices.
Double click on these devices and then click on the "resources tab at the top. Check to see that the resources are free and that there are no conflicting resources.
Let me know if this helps to resolve your problem.
Regards,
Graemevm
Apr 22, 2009 | Office Equipment & Supplies
Acer Aspire 5610-4648 Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
