Question about Pioneer Audio Players & Recorders
Magazine ball bearings lose - Pioneer Audio Players & Recorders
  • Gers48 Nov 04, 2008
    Thanks mate. My young son was responsible for pulling out all the trays when he tried to play some of his own CDs. I've had the unit for 16 years with no problems other than the occasional one caused by my kids! I figured I'd be up for a new magazine though as I've tried to piece it all back together. Still works as you say but I'm a bit concerned for its long term use.
    Cheers and thanks for the links to the new cartridges.
    Gers48
  • 1,512 Answers
If it is a pioneer 6 disc cartridge you are talking about,this happens from opening all the trays at once. They can still work ok, but do have a habit of jamming in the mechanism. When that happens, the load mechanism also breaks. get a new one to replace it ASAP
You can get 3 here for $35
You can also get singles from pioneer, but they work out to be a little more in price.
regards
robotek
Posted on Nov 04, 2008
What might be causing a Noise and rough pedaling from main crank area of the bike?
Sounds like a bearing issue in the "bottom bracket" or the housing that holds the cranks, in other words. I would remove the crank and inspect the bearings. There are several different types of bearings. If your bike uses sealed bearings, your only option is usually to just replace them. a "caged" bearing consists of several actual ball bearings, set into a round metal cage that holds them in place. If you have caged bearings, remove them clean them thoroughly, and then re-pack them with bearing grease before reinstalling. also be sure to clean the bearing cups, or any surface that they may come into contact with. Any dirt, sand, or grit makes for a quick death for your bearings. Some bikes just use free floating ball bearings set into the bearing cups. If this is the case, smear a blob of grease into the bearing cups. This will hold the ball bearings in place while you install the rest of them. Be careful when re-inserting the crank not to knock any of the ball bearings down into the bottom bracket. From the sounds of your description, you may be missing a ball bearing or two. Check to make sure there are no large spaces between any two ball bearings. If you could fit another ball bearing into the bearing cup without crowding any of the others out, then you are missing a bearing. Re-assemble everything as it came apart. When tightening the crank into the bottom bracket, be cautious not to over tighten. The crank arm shouldn\'t have any "wiggle" from side to side, and yet should still spin freely on its bearings. I sincerely hope this helps.
Aug 14, 2014 | Cycling
1999 toyota prado
where are you hands, we car blind here,
ball bearings are everywhere. car has 1500 to 3000 parts.
even the steering shaft has bearings.
inside car, outside car.
engine, transmissions, wheel bearings. axle bearings, CV balls.
where.
May 27, 2014 | 1999 Toyota RAV4
Grease wheel hubs
The race is actually threaded onto onto the axle it is best to only loosen the axle enough to add grease then tighten it back up. It is typical to use grease to make them sticky enough that you can get them back in place with out losing any.
P.S. if you do lose some then take a picture of your bike with you phone and put the remaining bearings in a clear baggy ands take these two item to your local bike shop. They will probably have some and may not even charge you for what you need. YOU HAVE TO TAKE YOU BEARINGS TO THEM SO THEY CAN MATCH THE SIZE.
Apr 19, 2014 | Specialized Crossroads
The bearings on my skateboard feel sticky, what causes this?
After a lot of use, skateboard bearings can lose their maximum speed. Once the internal balls of the skateboard bearings come into contact with moisture or dirt, the bearings will cease to roll smoothly.
Jan 17, 2013 | Sport & Outdoor - Others
I have a old 1.1/2 ton sears floor jack model is 328.12001
dont think seals will be available ,where it lock down to stay up is a ball bearing in a seat and this is worn .
May 07, 2012 | Cars & Trucks
Hi. I am attempting to replace the outer bushings (bearings) on a 1950s Atlas-Aire window fan that I have at home. It is one of those old fans with the expandable sides and a 20 inch blade span. It is...
Yes ball bearings will work, if you can't find bearings you can buy them from the international number on the bearing inner race from a company called King Bearing in Vallejo California.
Jun 27, 2017 | Dmm 2 Ball Bearing 12x40x12 Open:Ball...
I have a 1972 mt50 suzuki trailhopper,by chance is there little ball bearings in between the cases when i split my cases there were little bb looking ball bearings that fell out all the bearings are all...
no ball bearings between the cases,only alignment dowels, hollow in the center.if you have ball bearings they have to be missing from one of the internal bearings
Apr 07, 2010 | 2005 Suzuki Boulevard C50
The pull rope will not turn the moter. i took the top off and the ball bearing were all lose. what do i do
Best solution is to buy a new starting assembly -- it's shot.
Charlie
Aug 25, 2009 | Garden
Fauly aperture ring on mamiya/sekor 135mm f2.8 m42 lens
Does the aperture work when you turn the ring and push the aperture pin on the mount in? The lens should close down to the set aperture when you do this. If it does, then atleast the lens is useable.
What is missing is the detent for the click stops. This is a spring loaded ball bearing that 'clicks' into notches inside the ring. If this is broken or missing, finding a spring the right size might be a challenge, the ball bearing less so. To remove the ring and base, unscrew 3 screws coinciding with the 3 notches in the back plate, visible when you set the ring to f8. the back should lift off easily. don't lose the screws. The ball bearing, if it is still there, should protrude from a small hole in the lens barrel in line with the f stop index mark on the lens. Good luck.
P.S. The above is based on how my 200mm is designed so I'm making some assumptions that the 135mm is put together much the same.
Mar 27, 2009 | Cameras
53 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
