Question about ViewSonic NeoSat SP2104 Computer Speakers
How to turn up built in speakers on a toshiba laptop
Went into control panel to turnup no help
My built in laptop speakers don't play
need to go into the laptops setup and browse thru the listings..especially the audio stuff..
Jan 25, 2014 | Toshiba Computers & Internet
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached.
1st. make sure the volume is up all the way.
Then try using a headphone just to make sure the sound card is working.
If the headphones work then it should be a setting somewhere.
Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing.
If they don't work the sound card may be blown but it is still possible it is not.
Also, try Keyboard shortcuts for mute and UN-mute.
Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there.
If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
Sep 28, 2017 | Toshiba Tecra M4-S435 Tablet PC
In device manager there is yellow sign on PCI simple communications controller. How to update. I coonect headphone but still speakers of laptop giving sound
Hi!
When you see PCI Simpple communications controller, it normally points to the built in dial up modem on a laptop.. You can download the modem driver from toshiba suuport site..
Hope it helps.! :D
Sep 11, 2010 | Toshiba Computers & Internet
My laptop is playing sound at a very low level. All the volume controls are turned up to the max, but I can barely hear anything through the built-in speakers or through earbuds. Toshiba Satellite A101...
Usually what happens hear is that a program such as media player or a dvd player will have its volume turned down and that overides the overall volume.
The trick is finding it. You need to open up any and all programs you have used with some kind of volume control and check they are turned up then close them.
You will never get super loud sound on your speakers but they should be easily heard. I've run across this on both my tosh laptop and a desktop.
Apr 11, 2010 | Toshiba Satellite A105 Notebook
My laptop's built in speakers volume is full but
I am assuming you are using some version of Windows here; in the taskbar (by the clock) you will see the audio control-it looks like a loudspeaker. Left click it and the a volume control will open.
Mar 08, 2010 | Toshiba Satellite Pro A210-EZ2203X...
My built in mic (Toshiba L500-1GE) is not working properly (I can't use skype because people can barely hear me even when I'm speaking very loudly); tried to change sound (recording) settings and played...
I have a TOSHIBA L500 with WIN7-64
I have a problem with my mic, it started making this high freqency noise (when you put a mic close to speakers), so I had to turn the mic off in the control panel. Now I cant use the built in mic because it seems that it somehow deleted the driver. Can somebody help me with this.. I need to instal the built in mic for toshiba L500
Jan 05, 2010 | Computers & Internet
No sound from Toshiba A200 speakers
check the volume control, bottom right, in the notification area,
double click the icon, and raise it.
Or, Go to,
Start, control panel, sounds, double click on speakers, check it's enabled,
Or,
start, in search box, type run, in run box type DXDIAG,
enter the test area, test your sound in here.
should say no problems,
check connections to speaker are all good, if external.
Hope this helps.
Regards
Apr 08, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Disabled Satellite A215 internal speakers and now can't enable!
you may want to try and reinstall the driver from the manufacturers website. I had to do that with a brand new notebook as the speakers didn't work when first turned on. I'll see if I can locate a link and post again if I find it.
Mar 31, 2009 | Toshiba Satellite A215-S7407 Notebook
My speaker will not turn on
you need to go to control panel, click on sound, and then switch your configuration from your built-in speakers to external speakers.
Mar 02, 2008 | Audio Players & Recorders
New laptop
I had this problem too. My built in mic wasnt working, but i went to the list of programs (Classic view of the start menu) and under the program folder TOSHIBA > Speech System it'll have a choice "Configure Microphone." After I went through that, it worked fine. Make sure you restart your webcam software though after you've done that if you had it open like me. Hope this works!
Jun 07, 2007 | Toshiba (P000257700) Microphone
ViewSonic NeoSat SP2104 Computer Speakers Logo
613 people viewed this question
Top ViewSonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ViewSonic Audio Player and Recorder Expert? Answer questions, earn points and help others
