Question about Panasonic PT-61G54 61" Rear Projection Television
Dark picture good day hope some one can help. my screen just went dark i can still see picture but very dark if i turn up the brightness and the picture in setup. screen gets longer and gets deformed my setting were: picture-normal color-32 tint-26 brightness-36 picture-19 sharpness-10 at these settings picture was perfect thanks
  • Anonymous Nov 07, 2007
    the image looks ok only in cartoons but in everything else like movies loks dark and the brightness volume is to max
  • Anonymous Jun 27, 2008
    TV IS VERY DARK BRIGHT IS ALL THE WAY UP
    IT A COBY 15INCH
    Sergeant:
  • 337 Answers
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Posted on Oct 02, 2006
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Picture is very dark can hardly see in day time
try going into the menu and boosting the brightness.
Mar 06, 2011 | Televison & Video
TV was working fine till Friday 29 Jan 11. Went to turn it on screen was dark blue,but sound was on, after about 10min the screen went to bright blue then the picture came on. Saturday the same thing,...
The problem you are having is the power supply in the TV is failing. When you try to power the unit on you get on power or a slow turn on. It also can explain the problem of not running at full 1080p resolution because the higher the resolution the no power is required to operate the TV. Check out the article that explains the problem and how to repair it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 30, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
L13V36 Dark Screen, picture can be seen in bright light.
welcome to fixya
it sounds like the back light on both monitors are going bad
it might be better to call a repair man and get him to look at it see if it is going to be worth fixing i think it might be better then buying a new one at the prices now days
i hope this helps out have a nice day:)
Aug 08, 2006 | Zenith L13V36 13" Flat Panel LCD Monitor
Panasonic PT-61G54 61" Rear Projection Television Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
