Question about Compaq Computers & Internet
Removable disks A couple of days ago I had access to several removable drives (USB Ports) into which I would insert my thumb drive into one of. It showed the H; K; L; J; and M; drives. Now the system only shows the M: drive. What's worse is that now when I put my thumb drive in, my computer locks up. What can I do to restore the drives, and why is my system locking up when I insert my thumb drive. All of this just happened on Sunday. It was working fine on Saturday. I've been using my thumb drive for a long time and this has never happened before. What gives??? R,T. Hicks
    Genius:
  • Compaq Master
  • 1,250 Answers
Check your thumb drive on some different system, if its not working then its the problem of your thumb drive or restore your system to back date then check
Posted on Nov 04, 2008
The usb ports on my acer 5250-0650 do not work when a memory stick is installed.
Have the ports ever worked? Have you opened the computer icon to see if the flash drive is being detected- but maybe not auto-starting? Also, if a drive is inserted (Windows system), you ought to see the "safely remove hardware" icon appear on your taskbar, near the clock. Clicking on the icon ought to show you the drive by name & drive letter.
Lastly, right-click Computer>properties>device manager>expand disk drives>if your flash drive is shown here, highlight it & uninstall the device. Remove the flash drive, then reinsert it. Windows will reinstall the driver & this may allow it to recognize the drive again.
Let me know?
Cheers
Feb 25, 2015 | Acer Computers & Internet
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
How do i plug in my dane-elec flash drive?
Remove the cap and you will expose a usb plug. Plug that into any usb port on your pc.(perfered a port on the back of your pc cause those would be the most direct and powered ports)
Hope this helps.
Positive Feedback ALWAYS welcome :)
Mar 03, 2011 | Dane-Elec DaneElec 2GB USB External Blue...
I have a Maxtor 1Tb External Hard Drive that I have only used a couple of times on my PC - I did a full back up a few months ago and all was well. I added a couple of things to it a couple of months ago...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 09, 2010 | Computers & Internet
Indicator light illuminates but PC does not read the thumb drive. have tried pushing down the thumb drive as well as all the different ports on the hard disk.
The issue with the USB drive (assuming the device is working properly) is that Windows will assign it a drive letter, which is probably the E: drive. Since that's already in use it won't show up in "My Computer", but will make the USB noise and act normal otherwise.
To correct this you can manually assign each device their own drive letter (start with the bottom of the alphabet so there are no future conflicts).
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Jan 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Usb ports do not active
One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
Aug 23, 2008 | Acer Computers & Internet
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
Kingston usb pen drive
Most probably this may be a loose connection problem... and ur drive has a autorun program...
Situation may be like this...1. ur drive is recognised..2. Autorun starts...3. Drive disengages :))...4. OS asks u -->WHERE IS MY DRIVE???<--
Try using some other USB ports...and in some other PCs also...Try to have a thorough scan with good antivirus (Who knows.. may be some virus is running as autorun!)
Try connecting the device in all possible insertion levels
Bye
Have a nice day.
I hope ... this solves ur problem. :)
May 03, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
195 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
