Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Refrig compressor runs continuously
Just moved in to our new residence. Refrig was in storage for 8 months. Cleaned fan,coils and lower compartment. Supplied power. Freezer cools. Frig air flow low but with the litttle flow cools enough, though unefficient. And compressor runs continuously.Temp. controls have no effect.
    Brigadier General:
  • 6,966 Answers
Initially and based on past dealings, this could be indicative of a defective thermostat. Additionally:
  • it may be necessary to verify that the power is as required by your unit (voltage & Hz);
  • there is sufficient refrigerant (this however requires the services of a qualified professional);
  • the evaporator fan is turning at its prescribe RPM, there are no blockages on the airpath/vent(s);
  • check for sufficient ventilation on the rear of the unit and that there are no mechanical issues such as bent tubing, coils and others.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 04, 2008
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Genius:
  • 1,268 Answers
Sounds like your fidge is low on freon. You must check that one. Giving it a new freon will certainly give high cooling temp.
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Freezer and lower compartment do not maintain cold.
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jul 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Refrig cooling
check make sure all the fans are blowing one in freezer, one by compressor... should all be running when frig. is running
Aug 30, 2007 | Refrigerators
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
16 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
