Question about ElectroVoice SxA180 Subwoofer
No sound I've had recurring problems with the thing seemingly not starting up when I first power it on. It's like it's not even getting power. And since it has NO pilot light, you really can't tell whether it's getting power or not. Quite often, I fiddle with everything (cabling, etc.) for anywhere from a minute to 10 minutes, and then suddenly it's working and I don't really know why it wasn't before or whether the problem was even internal to the sub. Very frustrating.
Check the power supply filter capacitors - leaky caps / noisy supply / low voltage may not let the protection relay to energize. With a few minutes ON time, the caps may form - allowing the voltage to stabalize, and the relay will kick on. ( Just a guess )
Posted on Jul 12, 2009
Riding Mowers
You may need a 'heli' coil or a larger Spark Plug, it seems that the vehicle at operating temperatures is building up too much pressure and pushing out your current sized plug! Same thing happened to a me! And if its too much pressure, there is a 'filter' that becomes restricted, easy check!
Hopes this helps!
Dr. Gene n Landrum, PhQ. Quantum
May 19, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My iPod isn't working.
Okay. It seems like your iPod is stuck. Hold the home and power (screen lock) button together for around 10 seconds. Your iPod should reboot. :) If even after reboot, problem recurs repeatedly, it's a software problem. Restore it using iTunes or take it to you nearest Apple Service Center.
Jan 26, 2013 | Audio Players & Recorders
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
What's your problem?I've got a k650 partner saw that was starting and running great, really great. It ran out of fuel, we filled it, it ran for another 5 min and then died out. It didn&
You need to check it is mechanicaly sound, a compression test will give you a good idea, anything under 110 psi and you have a problem with either piston/ring wear, or it has seized.
Aug 05, 2012 | Garden
1991 toyota celica GT chugging
fuel pump sounds to be problem, though I'd replace air cleaner first to rule it out cheaper than pump (pump may have internal filters that are blocked)
Jun 02, 2012 | 1991 Toyota Celica
My problem is the same as the rest of these, My T9100 has lost the driver for the Yamaha AC-GX sound device. It worked find until I installed XP SP2, I've been to various forums and followed...
The 9100 series are famous for this problem, and it's more than likely hardware related and not driver related: the connector on the motherboard (where the sound card connects to) is probably loose - so it's not seeing the sound card (or only seeing part of it). Problem is probably caused by chassis flex over the years, and it's pretty common.
Solutons? Dunno... I've fixed about a thousand of these but over the years, about 1 out of 5 had the same problem recur, and I'm tired of fixing these things. Cheapest workaround? Get a cheap USB sound card and a cheap set of laptop speakers (cost me about $4 total) - a little cumbersome, but it don't cost anything....
Sep 19, 2011 | Toshiba Tecra 9100 Notebook
I have read all the msg boards and am still not able to sync my iphone 3gs to outlook. does it have anthing to do with running Vista? I used to work then notice that it changed
Vista shouldn't have anything to do with it, unless your using a 3rd party software to connect it.
First thing, Update iphone to latest version.
Update outlook 2007 using windows update.
The resent update to the iphone firmware and itunes fixed the problemof things not moving from iphone back to outlook.
BEFORE the fix for the iphone , to get an event to show up back in outlook , you would need to make it a recurring event on the iphone starting and ending on the one day ...
to test if thts the problem you have , make a new calendar event in your phone and make it recurring, starting and ending on the same day.
sync, then check outlook.
Before this update to get things working I needed to do the following...
1) backup your outlook .PST file. 2) rename and move the existing pst file, and create a new one.. 3)import the contacts 4) import calender events, (not recurring ones) 5)sync.
Taken from: stu @ http://forums.whirlpool.net.au/forum-replies-archive.cfm/1044679.html
Oct 19, 2009 | Apple iPhone Smartphone
F7 and then clock is lit up. The key pad for upper oven is locked. I can'tget it to do anything. Before this it came up bake at 350 degrees and push to start. I did this, even I didnt want oven on. I also...
OK, this code is signaling an issue concerning the key pad or control board.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 14, 2009 | GE JKP27 Electric Double Oven
Dell w2600
There is no fix for the W2600. It has a power supply problem.
For sometime Dell was replacing the tv's with new ones, but don't think they are anymore. If you go to the Dell Forum and type in your tv you will see the amount of people that have had the same problem. Unbelieveable. As a matter of fact, Dell is not even making TV's anymore. Guess they gave up. They cannot be fix, cannot get the parts for it.
Mar 20, 2008 | Dell W2600 26 in. LCD Television
ElectroVoice SxA180 Subwoofer Logo
148 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
