Question about Avid Xpress Pro
I am having trouble importing long HDV footage
Hi, I'm using Avid Xpress Pro version 5.7. I shoot on a Canon Vixia HV30, 1080/24p mode. I have not been able to capture from this camera into Avid, so maybe figuring out how to do that could be a solution, but here is the current problem:
I capture my footage in Adobe Premier CS3, and then import that footage into Avid Xpress Pro. Normally, I have not had any problems with this method. In fact, it has been downright convenient because Avid "quick imports" this footage much faster than other file formats I've tested out.
Anyway, I have only been capturing maybe 20 minutes of footage at a time, until now. I have a footage-heavy project and I must capture entire tapes at a time. I have made several attempts to import this footage into Avid but it fails every time with some error to the effect of "Exception: AudioElementaryStreamParser"
How can I fix this problem? Each file is about 01:01:00 long, and about 12GB. Is there some kind of cap on file import size? All of my Drives are NTFS formatted, so I shouldn't have problems with FAT32 filesize limits. If I absolutely have to, I can go back and re-capture my footage in smaller chunks, but the problem is that I have 26 hours of footage that I'll have to go through again. If there is some simple solution (or even not so simple) then let me know please.
    Genius:
  • 1,250 Answers
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
Mar 18, 2011 | Canon VIXIA HV30 DV Camcorder
Tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 | Computers & Internet
Tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step1: Install and Launch Doremisoft AVCHD Converter for Mac
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 | Computers & Internet
Can Avid Xpress Pro be installed on windows vista?
According to the manufacturer's spec, version 5.8 is not supported for Vista. It also requires a FireWire port ( 1394). The application key (dongle) is shipped in the box for legally obtained (first-buyer) software. If you didn't get the dongle, you will need to contact the manufacturer.
http://www.avid.com/products/1906.htm
The software will not work without the key. (Personally, I avoid such software since dongles get lost or damaged.)
I wish that I could be of more help.
Mar 20, 2010 | Avid Xpress Pro
Tip
Merge Canon Vixia HF11 AVCHD (mts) to Avid Media Composer 5 I'm a videographer...
I'm a videographer for Rasmussen College. I have a BA in Film with concentration in Editing and Sound Designing and here at Rasmussen College my video projects vary from internal communications and training, to marketing (adds) and video content for the online classes.
The little cam I own for my work is a Canon Vixia HF11 which records AVCHD in .MTS files; I also have a Sony EX1R. I decided to use Avid Media Composer for editing because they advertised that the new version (5.0) will import AVCHD footage. The problem with those AVCHD files is that they are divided in chunks of 2GB each and most of the editing systems do not work well with reconstructing the footage. There are little apps (like MTSMerger.exe) that will merge them into a big file, but I have problems to import even these new big ones. The next step is to use a third party transcoder to convert the footage into something that Avid will easily accept (and I choose .mov with H.264 codec). It takes me some time to find out one good AVCHD converter that meets my requirements calledAunsoft MTS Converter after comparing several similar converting tools. This is how the program looks like:
Though the standard .mov with H.264 codec works quite well in Avid, but I will love to have a tool that will transcode this AVCHD footage into XDCAM EX type. A direct transcoder from AVCDHD formats to let say P2 and XDCAM-EX type for use natively with Final Cut Pro and Avid MC would be great. And if this software will also take advantage of NVIDIA CUDA and/or MATROX MAX technology that will be awesome. In the mean time I will probably buy TMPGEnc 4.0 Xpress to use the Avid DNxHD Codec.
on Jul 26, 2010 | Cameras
Tip
Mac Sony HDR-SR11 MTS to Avid converter-Convert AVHCD to Avid I have Sony...
I have Sony HDR-SR11 AVCHD HDD camera to shoot family videos and beach videos. However, after I transfer .mts files from Sony HDR-SR11, Avid does not support the AVCHD file. I wonder the best AVCHD workflow into Avid from Sony HDR-SR11 and google for solutions.
I was recommended with Sorenson Squeeze to convert Sony HDR-SR11 MTS to Avid DNxHD codec. However, Sorenson Squeeze does not natively support .mts and the file extension should be changed to .m2ts. The conversion time is much longer than that the original clip. One thing should be mentioned is that the exported DNxHD is loaded quickly to Avid. Sorenson Squeeze also costs quite a lot. I just find a better Mac Sony HDR-SR11 MTS to Avid converter - Aunsoft MTS/M2TS Converter for Mac. The price is dramatically low comparing to Sorenson Squeeze, and the output MOV video works in Avid MC and Xpress Pro.
Here is how I import Sony HDR-SR11 camera videos to Avid Media Composer by converting 1920x1080 MTS to HD MOV.
Step 1. Load Sony HDR-SR11 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR11 MTS to Avid converter on Mac Snow Leopard, and click the "Add" button to load HD .mts videos.
Step 2. Choose AVC MOV for Avid.
Click the "Format" option, and choose Adobe Premiere/Sony Vegas > MOV (AVC)(*.mov), and the Sony MTS to Avid converter will transcode the HD MTS files to MOV for Avid MC, Xpress Pro.
Step 3. Convert Sony HDR-SR11 AVCHD to Avid.
Click the convert button under the preview window, and the Sony MTS to Avid Converter will start converting HDR-SR11 AVCHD MTS to HD MOV for Avid Xpress Pro, or the upgraded Media Composer 5.
As soon as the conversion in finished, you can import Sony HDR-SR11 videos to Avid Media Composer, Avid Xpress Pro for editing. The output HD MOV also works in Final Cut Pro and iMovie, and other non-linear editing software like Adobe Premiere on Mac OS X.
If you are using other Sony AVCHD cameras, you may also face the same problem. Have a look at the Sony HD camcorder page for Sony HDR-XR520, HDR-CX110, DSC-TX7, HDR-TG7 and other models.
(Canon HV-30) Firewire not responding any more with Final Cut Pro
SET YOU CAMERA TO FIREWIRE OUT, NOT AUTOMATIC!! <!-- from fixya rte -->
Jan 28, 2010 | Canon VIXIA HV30 DV Camcorder
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
While trying to capture a DV tape, avid freezes ( rainbow wheel )
Is it dv and not hdv? Have you selected the record format, using a native one is generally best. Take it you are using firewire directly, it could be the camera driver - codec, Can you borrow someone elses and try? Has it worked for you before (with and with-out that camera)?
Jun 11, 2009 | Avid Xpress Pro - (bundle) (05600360101)...
Avid Xpress Pro Logo
188 people viewed this question
Top Avid Computers & Internet Experts
Michael Galve
Michael Galve
castletech
castletech
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
