Question about T-Mobile Wing™ Smartphone
My password is not unlocking my t wing
Tried to manual reset but not working any ideas?
  • 2 more comments
  • Anonymous Nov 04, 2008
    asdfv
  • ide2 Nov 04, 2008
    I lock my t mobile wing and I tried to put my password but nothing happens. Need Help!!!!!!
  • Anonymous Nov 10, 2008
    dont know what i did but it is asking for a pass word and i cant get back in to my phone
  • mfull87 Nov 16, 2008
    it keeps telling me my password is incorrect
  • 66 Answers
You need to do a hard reset. this will reset the phone but it will also delete all memory
!- hold the two soft key(upper right and left key on keypad under screen)
2- while holding soft keys, insert stylus rset hole next to charging port on bottom of phone.
3. you will be given option screen to clear memory
Posted on Nov 16, 2008
I lock my wing phone , forgot password is there a special code to unlock it
if you did'nt change passcode from factory the code is 1234. if you have changed it you will have to do a hard reset. take out your sim card(just in case) hold down both( -- )tabs and the reset on the side. hope this helps.32452858-2-300-dt4.gif
Jan 23, 2010 | T-Mobile Wing Smartphone
Not able to detect service/ make calls, but it can text/go wifi.
Hi ,
This kinda problems we can not figure out untill we try something .
First of all go through the menu and search the network in manual and let's see if it finds any network by searching it manual selection if it finds the network you just have to select it or if
still it does not find any network
We could try
Factory Reset / Hard Reset
You can do factory reset through the menu mostly the default password is 1234. Try that and see if it fixes it.Or you can do a Hard Reset to it and then see.It can be done by holding down the two soft keys on the front of the phone (the soft keys are two buttons with a "-" symbol on them.
Hold those two down, at the same time, while pressing the reset button on the side of the phone. It's a small hole just below the volume slider. You can press it with your stylus pen. This will erase all data, and restore the phone back to factory condition.
If above solution does not work you really have to see the support center .
Best Regards
Jun 23, 2009 | T-Mobile Wing™ Smartphone
Lost password to my t-mobile wing phone
hold down both soft keys and press the reset button
Sep 08, 2008 | T-Mobile Wing™ Smartphone
Resetting System Administration login password
Hi Carrie,
Sorry I have been installing a system in a remote area and they do not have Internet access as of yet. Here's what you need to reset the System Manager Password,
Feature 9 8 5, display will read " Set : ### ", press " 9 ", enter the following using the dial-pad: 7 3 7 3 8 7 6 7 7 9 3, display will read: " reset password? ", press YES, press RLS. This should fix the logging in problem. Let me know, ....Mike
Aug 22, 2008 | NorStar M7310 Corded Phone
T mobile wing user code unlock
gregorydtatum@yahoo.com i had the same problem you must do a hard reset it will wipe out all your data (phone nums etc...) but it will reset your phone to factory default. heres how:
1 there are two soft keys on the wing one is the button on top of the send call button the other is a button ontop of the end call button hold them both down at the same time.
2 there is a reset button on the left side of the wing (above the place the micro memory card goes) use your stylus or something to press the reset button for 1 or 2 sec then release the reset button while you are still pressing and holding the two soft keys
3 continue to hold the 2 soft keys the screen will turn black and a message will be displayed (giving you a warning that all your data is about to be erased do you want to cancel or accept the reset) you must choose accept and the phone wipe data back to factory settings and unlock all you have to do now is reprogram contacts and whatever other info you had in the phone
if you do this right you phone will be back to normal i promise e mail and let me know if you fixed it p.s. if you could help me find the wing unlock code if you know it and the procedure to unlock to another carrier please tell me
peace, TATUM
May 24, 2008 | T-Mobile Wing™ Smartphone
I can not unlock my T-mobile wing
Just do a factory reset
Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
May 09, 2008 | T-Mobile Wing™ Smartphone
Wing
You can do a hardware reset of the phone. To do this hold the two soft keys in the front of the phone while depressing the reset button on the side. The rest button is located at the bottom of the volume level slider on the left hand side of the phone. You will need to stick a pen or something in there..The two soft keys are directly on the front of the phone right above the "ok" button and windows button.
It is very important that you do that all at the same time.. Release the "reset" button while still holding the two soft key buttons. After a couple seconds a black screen will appear telling you that it will erase everything..Just accept and that's it
Apr 26, 2008 | T-Mobile Wing™ Smartphone
Unlock code
Just do a master reset it will delete that password and give you the option to put in a password of your own. Go to the t-mobile web site, look for the manual it will give you instructions on how to reset the phone.
Forgot my password
Just had this problem too... called tech support they said to do a hardware reset....press and hold the 2 dash buttons on the front then while holding those down out put the stylus in the little hole on the side by the volume and push it in till you feel is kinda click hold all 3 for about 3 seconds then take the stylus out... the screen should ask you if you want to reformat hit yes and it dose it... only thing is it deletes EVERYTHING on your phone and sets it back to factory... just like it was brand new.... thats the only option they gave me.. hope it helps. :D
Dec 25, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
53 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
