SOURCE: Miele G646SC Plus dishwasher Drainage / inlet warning light
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
SOURCE: Miele Novotronic G 841 Plus keeps stopping after a few minutes
There's a rectangular slot under the triple filter at the 12 O'clock position. The circulation pump impeller wheel faces you inside that hole. I would recommend using a special wrench for doing just that. The box wrench could get stuck and break off a blade on the impeller. I think Miele will mail you the special tool for free if you call them with the Model and Serial number. They say the pump seal inside there gets tight if it's not used on a regular basis and the hot water or the tool frees it up. I think they could use ceramic washers instead of rubber. They don't change size so there would be much less tourque required to start the pump.
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
SOURCE: Obtaining Miele Dishwasher parts
Miele's US website lists a toll free call in # for parts under the customer service heading. I found them to be helpful and informed. See below:
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
