Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
About connectivity problem
Sir i have a cable that is direct connect to a switch and i connect that cable to another switch another switch is d-link 8 port switch now i connect 4 pc to another switch
then i face a problem it is internet connectivity problem i am surfing internet only on one pc
and another pc is able to ping with all 3 pc but internet is not working so plz tell me about it?
  • 3 Answers
Sir please use a router where you can connect all your switch's. However router needs to be configured properly based from your internet type and settings
Posted on Nov 05, 2008
I have small network in an office, with 8 - port Ethernet switch. after buying two new PCs, i have tried to expand the LAN by adding another switch and i couldnt dont know why. i have connected the two...
Sir your computers are not in the same workgroup that's why coundn't ping the computer please open up *my computer then right click in it and go properties then on to the computer name > network id at the right side of that properties then add you network name what ever your have then it will work properly
( Note: do these things on that computers which is connected to the other port)
Thank you
Mar 29, 2012 | D-Link DES-1008D 8-Port Ethernet Switch...
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to connect two 8 port dlink switch?
You have to interconnect the switches with the cable. Connect the computers to the switches. Also connect the internet cable in the switch too.
Aug 27, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Can connect ps2208b to my desktop pc
sir
cable length is 100 meters long. how can i connect?
Apr 13, 2009 | SMC Compex PS2208B 8 Port 10/100 Fast...
CONNECTIVITY PROBLEM WITH 8 PORT D-LINK SWITCH FOR MORE THAN 3 PC
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
KETAN PATEL
Mar 11, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Please tell - the mercury mother board p1865d7 - how we connect the reset button and start button on mother board. please send the diagram. i could understand. thank q sir jitendra
OK, Here is a picture:
As you can see the Reset switch is connected to pins 5 & 7 and the Power switch is connected to pins 6 & 8.
This is directly from the manual. You can download it from:
http://www.mercury-pc.com/downloads_list.php?productid=684
The link is at the bottom of the page.
Thanks for using Fixya. A "Fixya" rating would be appreciated.
Jan 22, 2009 | Mercury KVM400M-U Motherboard
Switch to switch connection
in the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Jan 16, 2009 | PC Connection Cross-Over Cable (363003X)
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
267 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
