Question about NewCon Optik LRB 4000 CI Rangefinder
Problem about measure
Dear Sir or Madam I have been using my LRB4000CI since January and it was working OK, but last week I lend it to an office partner, and when he tried to use it did not measure any distance. I have set the mode to STD2, and it started to measure from 25 to 108 meters, but I'm certain that the distance is more than 150 meters. I have read the manual and it says that there is gatting option. I think the rangefinder is not working with that option, well I am not sure. Could you please tell me if there is anything I can do in order to make it work again?. I am an electronic tehnician, but I only want to open the device if I am certain that I could repair it. Thank you for your help
Office for windows 2000
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Solution for your problem you can still find at this adress.
Here you go, use this software in order to use any Office file on Windows 2000, compatible with everything you need.
http://www.openoffice.org/
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Microsoft Computers & Internet
Dear sir/madam, when i want to use microsoft it is locked because modification isnot allowed. Thank you for your help. your sincerely, mohammad
What you have is a "trial" version of Microsoft Office.
Your "trial-period" was either 30 or 60 or 90 days.
Now that you have completed that "trial-period", you must purchase a license-key to use _all_ features of the software, e.g., the capability to modify existing files.
Jan 15, 2011 | Microsoft Office Professional 2007 Full...
I started having problems wth my yahoo messenger last week after installing it it worked for about 2 days before it stopped showing what I or the preson I'm chat with writes. I tried uninstalling and...
hello dear sir or madam:
you shulld buy the 10 messenger the old is one is not good to use for this i advice you to buy the new one it is good for video chating and full of fuction
thanks
ajmal safi
Dec 08, 2010 | Yahoo Messenger
Dears Sir/Madam, What are the likey causes of an intermittent indicator light failure in a Hyundai Lantra. They usually work OK at startup and then fail after a few uses. Maybe related to temperature....
are you referring to the yellow signal lights on the outside of the vehicle? if so, check each light to see if one is blinking faster than the others, or if one does'nt light at all you might need to replace the bulb...
Mar 18, 2010 | 1994 Hyundai Excel
Error code 007 appears on my canon iR2018
Hello sir; You may go to make a reset procedure as follow; press "additional funtion"(*) key "2" and "8" key in order, then sssw will display, press "OK" key, then select menu item 1 using up/down arrow key, select bit switch 1 using left/right arrow key, then change data from 0 to 1 or from 1 to 0, then press OK, press Stop .
Sep 16, 2009 | Canon Office Equipment & Supplies
Installation of ms office regarding
Hello Sir/Madam,
First u copy the installation files of ur pen drive into your system. Then install it. The problem will be solved. ok
Thanks
"Don't Forget to rate the solution"
May 20, 2008 | Microsoft Office Professional 2007 Full...
NewCon Optik LRB 4000 CI Rangefinder Logo
Top NewCon Optik Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
