Question about Intermec 700 Series Mono Mobile
Ntermec 700 Series Mono
Hi, i want to know if there is a manual with errors of this terminal. Thanks
Cover open error even when cover is closed
Open the printer replace the cover sensor if you don't find the rocket wire or terminal.
Oct 20, 2015 | Brother DCP-1510 Laser Multifunction...
Hi I have just bought a Sony 820av amp and tannoy sfx speakers. I have got all working except my sub. Can anyone advise me on correct cabling for the sub to amp?
Sub woofers are just mono amps. They feed both the right and left output together. So all you need is a stereo to mono cable. The two jacks go in the sub and the single mono into one of the terminals on your amp. The other terminal will allow another sub to be connected I think, though please check your manual for this.
Jan 17, 2013 | Audio Players & Recorders
Bridging outputs on JBL BP300
Hello paulnkate,
The BP300.1 is a mono (1 channel) amp. You cannot bridge a mono amp. Bridging is a method of combining the outputs of 2 or more channels of a multichannel amp into a single mono load. On your amp you would connect a single sub to one of the +'s and one of the -'s (either one is OK, they are connected internally). The other pair of terminals is just for convenience, making it easier to connect, if you want to power 2 subs.
Hope this helps.
Jul 20, 2009 | JBL BP300.1 PowerValve Series Car Audio...
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Hafler 9505 amp, has noisy output in mono.
Hi Don,
When you bridge the outputs , do you connect only to the ( + ) speakers terminals for your output. This is what the manual says to do.
Let me know
Scott
Apr 07, 2009 | Monster Cable MPA3250SS 3-Channel...
Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Jun 21, 2008 | Sony XM-754HX Car Audio Amplifier
Lanzar optidrive series 4000watts mono block digital compitition class amplifier
Firstly, sorry to to tell you, but their is no such thing as a 4000 watt car amp. Google Ohm's law and RMS .
Check the owners manual or website to find the amps minimum impedance. Usually 4 or 2 Ohms. Next,
check the woofers impedance , If unsure check with a Ohmmeter,
It's actually the resistance,but close enough.
If they are 8 Ohm and you twist those wires together (parallel circuit) your amp will see 4 Ohms.
If they are 4 Ohms (paralleled) your amp will see 2 Ohms.
Do not connect in a series circuit (+ amp terminal to a + speaker terminal and that speaker - terminal to the other speakers + terminal and that speakers - terminal to the - amp terminal) .
It creates phase problems, and sounds like ****.
Most mono amps are really internally bridged stereo amps ,it's cheaper that way, but it limits how low of a impedance they will handle. Read the specs. Use the correct size connectors, scrape off paint for a good ground connection.Use the right gauge wire and above all. Fuse that power lead at the Battery!!!!!!!!
ps . if you have dual voice coils thats another chapter.
Good luck, Sumthin
Jun 11, 2008 | Lanzar Car Audio & Video
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Wiring 2 subwoofers to a mono amp?
The subs can be wired "parralel" or in a "series". it depends on the ohm rating of the speakers and the amp. Most amps can only go down to 2ohms (mono) so it depending on the ohm ratings of the speakers when wired in a series vs parralel that will decide how to wire them. you can always take the safe route and just wire the positives of each to positive on the amp and the negatives to the negatives on the speaker terminals. Do you have the speakers model numbers?
Dec 14, 2007 | Car Audio & Video
Presario 700
Hey check the following link for compaq presario 700 manual:
http://www.geocities.com/hpmsgs/700xx/
Nov 18, 2007 | Compaq PRESARIO 700 SERIES 14.1 LCD Hinge...
Intermec 700 Series Mono Mobile Logo
556 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
