Question about Phoenix Gold Tantrum BASSCUBE Car Equalizer
Basscube remote knob wire
I have a tantrum basscube with the bass remote, but no wire, I used a phone wire to replace the wire, and well nothing worked it used to work but the jerks at the shop never pulled the wire out they left it in the car, but any way it powers up but I cant get it use the remote. oh well hopefully thats enough info thanks for the help
    Problem Solver:
  • 17 Answers
Sloth...
funny seeing this question posted here... I worked at Phoenix Gold for 4 years, and I can help you with your problem.
when the BassCUBE was designed, the engineers didnt realize that a standard phone cable is what we call a "flipped cable", where if you were to lay the cable flat without any twists in it, on one end the connector would be tab up, and the other end would be tab down. on a standard RJ11 plug (the phone plug), the telephone requires that the pinout is as follows:
#1 - Black
#2 - Red
#3 - Green
#4 - Yellow
But the BassCUBE needs a non-flipped cable, which are hard as heck to find... so I will give you the quick easy fix.
You need a 2-line (4-wire) telephone cable that has a black, a red, a green, and a yellow wire in side it, and you will need 4 crimp caps or other way to splice the wires back together. You then need to cut the wire in half, and carefully seperate and strip each wire on each piece of the cable. Call one piece "Part A", and the other piece "Part B". Then you need to splice the cable back together as below.
Part A Part B
Black ------------------> Yellow
Red --------------------> Green
Green -----------------> Red
Yellow ----------------> Black
Once you have done this, and your SURE that your splice is good (not shorted out), then go ahead and plug your modified cable into the BassCUBE and its remote control, power it up, and you should be good to go.
Posted on Dec 09, 2008
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello
I've got a phoenix gold bass cube and I've broken all the wires that go to the volume control not too sure what order the wires go back in could you help or give me a diagram
Many thanks
Posted on Oct 12, 2015
Tip
Manual
Here a copy of the manual in PDF format:
ftp://www.rodinaudio.com/Phoenix%20Gold%20Mobile%20Audio/Manuals/Processors/BassCube%20Manual.pdf
on Aug 02, 2008 | Phoenix Gold Tantrum BASSCUBE Car...
No speaker output from Basscube 8s
Yes. Check your connections that you are using from your preamp/processor or receiver to the Basscube to confirm that any adjustments I'll give you instructions for will go to the correct output. There are 2 ways that signal can be connected to the Basscube, your inquiry does not describe which you are using; either speaker level or line level. Line level is the easiest as it uses only one cable so I'll assume that is what you've used.
The following instructions I'll provide you with will presume that you are using a digitally controlled receiver or preamp/processor with an LED or LCD display and remote.
On the preamp/processor or receiver, navigate to your speaker setup menu and adjust the frequency output of any bass management system it may have to a full range signal. This may be a setting labeled for speaker size for example, choose "large." Or, if it has just a crossover setting, increase that to it's highest value.
Then go to the rear panel of your of your Basscube. Adjust the crossover to about 120Hz.
Return to your preamp/processor or receiver. Navigate to your speaker level control on the speaker setup menu. Increase this level to a matching value for each channel until you can hear your Newton speakers.
May 16, 2012 | Cambridge Soundworks BassCube 8S Speaker
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
Feb 20, 2012 | Cambridge Soundworks BassCube 12 Speaker
Has humming sound when powers on
You may have a power problem. Check to make sure that your wires aren't touching and not crossed.If this doesn't help try plugging in you sub to different plug could be getting interference electrically in the spot it's in
Feb 06, 2011 | Cambridge Soundworks BassCube 15 Speaker
Basscube 10 dead...need zener and resistor help
The zener diodes are 1N4774, I believe they are one watt. Try 3 watt metal oxide for the resistors. You might as well replace the 6800uF 63 volt main filter capacitors and the 220uF 50 volt capacitors while you're at it. Half the time the heat that cooked your other parts takes them out as well.
Jul 17, 2009 | Cambridge Soundworks BassCube 12 Speaker
Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Dec 13, 2008 | Cambridge Soundworks BassCube 12 Speaker
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Phoenix Gold Tantrum BASSCUBE Car Equalizer Logo
1,778 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
