Question about Brother MFC-8820D Laser Flatbel Multi-Function Center (MFC 8820D, MFC8820D) Printer
Brother MFC-8820D Machine Error A
This AIO printer gives Machine Error 7A. The code stands for: Main motor is not synchronized withe the reference clock". How can I repair it? what is the most likely problem? Is service manual available, at least pages related to this error? Thank you.
  • w00w Jul 21, 2008
    Machine error 7A
  • 1,218 Answers
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
The top hopper on the Brother8820D is not working. How can I fix it or take in for repair.
Posted on Apr 03, 2008
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
What is an 7A Error
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
Aug 19, 2010 | Brother IntelliFAX 4100 Laser Fax
What is error 7A
Jun 23, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock. for more information and help........
Mar 04, 2010 | Brother MFC-8440 All-In-One Laser Printer
When i turn on my brother mfc 8440 it is saying
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother printers mfc 8220 error 7a
Jul 23, 2008 | Office Equipment & Supplies
ERROR 7A
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother laser mcf-8440/ machin error 7a
Oct 26, 2007 | Office Equipment & Supplies
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
See all Brother MFC-8820D Laser Flatbel Multi-Function Questions
Brother MFC-8820D Laser Flatbel Multi-Function Center (MFC 8820D, MFC8820D) Printer Logo
868 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
