Question about GE Monogram ZISS480DRSS Stainless Steel
Refrigerator temp disply shows off /off
Seems the door was paertially open for some period of time. Now it does not seal when cloasinf and it seems not to be cooling. I have resent the temperature but after a few mintute it returns to the off/off display
Read manual. Indicated need 24 hous to stabilize. Minimized use and it reset OK. Thanks
Posted on Nov 06, 2008
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
GE Monogram side by side refrigerator not cooling, door not sealing either
You gave an excellent description, but you listed it on the Cars and Trucks section. You will not find too many Experts for Refridgerators on the Cars and Trucks section.
I would listen to the E3 Code and use your Web Browser for your make of appliance. Ask questions like "What is E3 defect in your brand of appliance?". The magnet idea is a good one, but check your door pivots at both the top and bottom of the Fridge. The door may not be aligned.
Some appliance makers have online Manuals for their customers.
For parts or possibly the answer of your E3 question, try Servall. They are a franchise, have been around for over 50 Years and may be listed in your phonebook. If not they have a Website. Also may be spelled as Serveall, but I think it is Servall.
I hope mu solution is helpful.
Sep 11, 2012 | Cars & Trucks
In edit mode my oven seems to warm up past the preset temps and trip the overheat relay, also in cool down mode when i open the door it shows the IR steadily going higher to 1000F and seems to stay in cool...
Bad SSR relay, te relay is shorted it keeps feeding the power to the it element . Or else bad IO board. You should know how to diagnose it though. Otherwise don't touch it
Feb 18, 2012 | TurboChef TORNADO Electric Oven
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerator trouble shooting
Condensation only ever happens if the door is left open for a long period. - The warm ambient air condenses on anything cold - like the food in there.
Because of convection, the door need only be open 1/4" to be affected. Quite often a bag pushes the door open a little.
Check all door seals for splits - clean them.
Make sure nothing is touching the back cooling plate, and it should be fine from there.
Hope this helps.
Jun 11, 2008 | Refrigerators
GE Monogram ZISS480DRSS Stainless Steel Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
