Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
WHIRLPOOL REFRIGERATOR DOES NOT GET COLD
IT WAS WORKING FINE, SUDDENTLY NOT GETTING COLD, ONLY AIR OUT
PLEASE HELP
  • Anonymous Nov 14, 2008
    It is a little cold but not very much.
    The Freezer is the same. All the frozen foods thawed but not the ice>
  • 958 Answers
Please check the compressor at the back if it is running.
if not, try to unplug for about ten minutes the replug it back..let me know if the compressor did run.
tnx 4 using fixya,
drcool
Posted on Nov 04, 2008
Refrigerator set on 5 the coldest and there is a water dripping
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My refrigerator wont get cold and it is on the highest temperature possible the freezer is working fine. its still makeing ice but its just that the refrigerator wont get cold. its also 10 years old.
Always set the controls to their "normal" recommended setting. Changing them will not work. Is there air blowing from the freezer? The freezer fan may not be working. Or if it is, possibly the air flapper could be stuck closed not letting air flow into the refrigerator.
Dec 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The reezer works fine it is the botoom fridge that frezzes up and stops air flow to keep cold thanks bellystar
I will try to help you but you need to look around the door and near floor and behind the fresh food section door. I need the model of the Whirlpool refrigerator. Sounds like the thermostat is stuck or broken on as cold as it gets. There are just too many models to guess. This still may take a little work so let me know when you are ready, Thanks for understanding, Sea Breeze
Oct 20, 2009 | Whirlpool Refrigerators
Hello, I have a Whirlpool refrigerator that is just over a year old (Model #ER8YHMXSB00). The freezer seems to be working fine but the refrigerator will not cool below approx. 50 deg F. This just started...
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermistor is not registering the correct temperature causing the fan not to turn on.
Thank You for using Fixya.com
Jul 31, 2009 | Whirlpool Refrigerators
The refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
Jul 03, 2009 | Whirlpool Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
