Question about Olympus Camedia Brio D-150 Zoom Digital Camera
Focus, blurry pics
Camera suddenly is having problems with the focus. Sporadically will take crystal clear pics but more and more slightly blurry pics. I can take a dozen pictures and maybe a couple or so will come out clear.
  • 255 Answers
SOURCE: Focus Problem
I have the C740, which I believe works very similarly if not identically. Unless you have the camera in full time auto focus, I don't believe it actually focuses on the subject until you've pressed the shutter button half way. Until then, the subject may look in focus in the viewfinder, but is not. When you fully depress the shutter in one motion (rather than pressing half way first), the camera will attempt to focus before it takes the shot. If you are not careful about camera movement, you may inadvertently be focusing on something other than what you intended. My camera (and it seems all digicams) has trouble focusing in low light, so you definitely want to use the half press in such situations. Even then, I don't always get the focus correct. Thank the digital Gods for instant feedback! Personally, I almost always use the half press method. To get the 740 in manual focus, you hold the "OK" button down until you see the viewfinder display a focusing scale. It takes a second or so. You should also see "MF" and "AF" designations in the lower left corner of the viewfinder when the scale displays. Use the left and right arrows to select the focus mode you want (i.e. MF or AF), then use the up and down arrows to adjust the focus distance. You'll notice that the area you are focusing on is enlarged when you use the up and down arrows.
Posted on Sep 13, 2005
  • 75 Answers
SOURCE: Olympus FE-130 will NOT focus
It sounds like the focus motor in the lens is jammed. This could be caused by a knock or possibly sand. You could try tapping the camera (not too hard...). This might free up the motor the only other solution is to take it to a shop.
Posted on Apr 17, 2007
SOURCE: Olympus FE280
I just had the exact same problems today, I found this post by searching the Internet for solutions. =) By fiddling around I found a solution that worked for me. If you hold the lens once they're "down" as they are spazzing out, gently but firmly keep your grip so that the lens is flat against the rest of the camera as it tries to expand forward. Keep holding and wait until the camera turns off by itself. Then turn it back on, and voila! It worked for me, the blurriness was gone and I could zoom again like normal.
Posted on May 12, 2008
  • 919 Answers
SOURCE: Olympus 1010 lens stuck out. Won't shoot either
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Mar 30, 2009
  • 5 Answers
SOURCE: camera was dropped and now doesn't focus
get a new hard drive
Posted on Jun 04, 2009
  • 11967 Answers
SOURCE: My Olympus FE-320 will not focus. When I turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
0 characters
1 Points
Non-zoomed pics are in focus but as soon as I zoom in, even slightly, pics get very blurry. What settings should I be adjusting, please?
M stands for macro.this is for extreme close so dont take photos with m displayed unless extreme close
Jul 06, 2015 | Sharp Digital Cameras
Blurry picture if zoom is used ( no Sharp mage)
I'm out of practice because my camera suddenly stopped working 6 months ago, but I don't recall having a problem with blurry pictures when I used the zoom. Sometimes, it takes a few seconds for a pic to come into clear focus. I think the trick is to just keep working with it.
Jun 20, 2014 | Canon PowerShot SX100 IS Digital Camera
How do I take clear pics of xmas lights so they are clear
The camera is having problems focusing. Try focusing on a bright object hold the shutter button half way down to lock the focus then frame your image and press the shutter to take the photo.
If this does not work then try manual focus.
Dec 11, 2012 | Kodak EasyShare C653 Digital Camera
How do i take pictures of christmas lights so they are clear
When i turn on my camera to take a pic it is blurry but if i zoom the lens all the way close to the object it takes a good pic.
Your auto-focus is not working. Inside the camera is a motor that adjusts the lens to focus on an object automatically. It is currently stuck to "close" or near focus. However, it doesn't go far focus. Check the focus functions of you camera - try to use manual focus.
Dec 01, 2010 | General Electric A735 Digital Camera
I have a Nikon D40x digital camera. The problem began when the screen began showing some type of diagram over the picture I had just taken. The camera then started having difficulty with auto focus. ...
Seems possible that the servo control /main processor control is faulty and will need help from Nikon service , It will be better to get a evaluation for the fault and so we can have a consenses on the fault.
get estimate and decide.
Sep 28, 2010 | Nikon D40x Digital Camera
Blurry Pics
Does this happen on every picture? Sometimes if you change what you're aiming at slightly, the camera will focus.
Sep 05, 2009 | Digital Cameras
Casio Exlim--camera
i have an exilim camera too the 7.2 pixle. And im having same problem the day before i took really clear pix and now its just all blurry ... everything else works fine .. i never droped it or wet it .. i view the old pics and there really clear why is my lense sooo blurry now? help
Dec 20, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Blurry Pictures
Contact Customer Support this is possibly a CCD problem- they may still fix it.
May 29, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Olympus Camedia Brio D-150 Zoom Digital Camera Logo
15 people viewed this question
Top Olympus Digital Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Digital Camera Expert? Answer questions, earn points and help others
