Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Refrigerator Compressor hot to touch & fridge/freezer not cooling
I have a F&P E372B refrigerator, the compressor is very hot to touch, & fridge/freezer not cooling,the fan in freezer works,I removed the defrost cable no change, relay & overload tested ok. is the compressor drawing to much current? If so can this be fixed without having to replace compressor & regas etc? Is there a reset button? Help.
  • 1 more comment
  • francis rivero May 11, 2010
    is the compressor running if you plug the refrigerator? i mean is it vibrating and the pipe is getting hot?
    drcool
  • joshdonhardt May 17, 2013
    Could also be the start capacitor. Check that as well.
  • butlerjim5 Jul 03, 2013
    The black housing sitting on the drain pan is hot. The freezer is working fine
    Genius:
  • 1,122 Answers
You need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
I have a Kenmore model 106.58964700 that both the freezer and refrigerator stopped working. The service technician said it was the start relay (Sears part number 2319792). I replaced the part with one...
Daleb870, Compressors on referigators run hot to the touch. You are experinceing a couple diffrent issues. First off 0 and 36 is a very ideal temp. The compressor and tubing are most likely hotter than normal as it was trying to cool down a fridge that was house temperature. After the fridge runs for a while and the load on the fridge is equalized the tubing will not be quite as hot. It and the compressor will still be very hot to the touch. The compressor its self right aroung 130f. But its normal.
Sep 01, 2011 | Refrigerators
Refigerator not cooling and hot to the touch
It sounds a lot like lost charge caused by a leak in your system. If your unit has been moved or improperly cleaned, some part of the pressurized system may be damaged.
Refrigerant (with very small molecules) may leak off over many years but it shouldn't happen in the single digits.
Apr 05, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Losing coldness in freezer and fridge. side panels near freezer door are extremely hot to the touch. bottom back of the fridge is extremely hot.
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
Jun 10, 2008 | Frigidaire Refrigerators
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
3,716 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
