Back to:
Tags:
Emerson EWC1903 19 in. TV/VCR Combo
Tv wont turn on
posted by bryanbeam on Oct 02, 2006
the last thing watched was cable tv station.
then it was powered off.
a few hours later my son tried to turn on tv and nothing.
power supply is good to tv.
I noticed a light buzzing/whinning sound when tv is plugged in, and it goes away when unplugged.
It almost sounds like a very small electric motor running when it's plugged in
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 02, 2006
Helpful (85)
jomaru
Rank:Guru Guru
Rating: 87%, 448 votes
The sound can be called screaming from the power supply,it senses a short and creates a frequency you can hear,the set has a problem and it needs to be repaired,I will check the horizontal out put transistor for a short,sometimes it goes bad without a reason and sometimes the high voltage transformer is also bad and both have to be replaced but first the transistor only if it goes bad again then you replaced the transformer too.Seek assistance from a servicer if you are not too familiar with tv service,it can be dangerous.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tv wont turn on:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
i have a 27 in sansui - model is tvs2746a. i am askin is...
TV Combos
tv turns on screen comes on normally for about a minute or...
TV Combos
I'VE GOT A FERGUSON TV/VCR FTC2120T BUT THE REMOTE CONTROL...
TV Combos
Both speakers work on the tv if you swap them over - but...
The TV part of TV/VCR works fine, but a repeating sequence...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
