Question about Quadrant MB-AT-5MVP3 Motherboard
USB PORTS my girlfriend had a computer built for her and she didnt realize that the usb ports never worked. I put a new usb card in the computer those didnt work either. The usb ports are hardwired into the mother board. I have checked the bios and the usb is turned on. Do I need to change anything else in the bios? Any suggestions on what may be the problem and how i can fix it?
    Novelist:
  • 208 Answers
OMG, ANOTHER HORROR STORY OF CUSTOM BUILT COMPUTERS! THE THINGS PEOPLE DO WITH THESE COMPUTERS, THEY SHOULD HAVE TO WORK ON THEM. I'M REALLY SORRY YOU'RE HAVING PROBLEMS, AND NOT KNOWING THE COMPUTER MAKE I'M GOING TO SUGGEST TRYING SOMETHING THAT MIGHT SOLVE YOUR PROBLEM. YOU SAY THE USB PORTS WERE HARDWIRED TO THE MOTHERBOARD AND THEY ARE ON. THIS MIGHT BE THE PROBLEM. HAVE YOU TRIED TO TURN THEM OFF AND THEN INSTALL THE USB CARD AND REBOOT? SEE IF THE COMPUTER WILL RECOGNIZE THE NEW USB CARD IN THE SLOT INSTEAD. THIS MIGHT DO THE TRICK. HAVING THE HARDWIRED USB TURNED ON WOULD CAUSE A CONFLICT WITH TRYING TO INSTALL ANOTHER USB CARD. ALSO, HAVE YOU TRIED USING A USB MINI-HUB INSTEAD? POSSIBLY THE MINI HUB MIGHT BE AN EASIER SOLUTION, SINCE THEY SELDOM NEED ANY SOFTWARE ETC. TO FUNCTION. I HOPE THIS GIVES YOU A COUPLE OF IDEAS TO TRY AND POSSIBLY SOLVE THIS STICKY PROBLEM. IF YOU NEED MORE HELP JUST REPLY TO:
ARCLIGHT1217
Posted on Nov 04, 2008
Xl 400 singer futura usb port shows up not connected everytime we try to use the embroidery software. Software will not appear.
I have a singer quantum xl5000 embroidery machine. One Thing I can tell you is that you have to use the original cord that came with the Card writer. The cables that come with the card writer is a null modem Cable. It suppresses the modem signal through the computer to the cable. Then you can adapt it to say USB with another cable. You hook your new cable to the cable that came with the card writer. The original cable must be hooked to the card writer first. Then use an adapter or the new cable to hook to the computer. The new cables Must also have a fdti chipset in them. If you have all that your computer will be able to talk to the card writer and it will work. If it still doesn't work then your USB port needs a new driver. You might check the USB port first to make sure the drivers good. That's very simple just go into the control panel on your computer click system folder and go down through the list until you see the USB ports your porch should be listed. Just click on the file and see if it says working properly if it doesn't realize the driver
Nov 03, 2013 | Sewing Machines
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
Software is unable to find Olympus Digital camera connected to USB port
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 31, 2012 | Olympus TG-320 Tough 14MP Blue Digital...
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
Where do you put a n SD card into a computer?
Some computers have a built-in SD card slot along with other types to read the cards. If yours does not have the slots, you can purchase an external adapter that can plug into a USB port.
Dec 31, 2010 | SanDisk 2GB microSD Memory Card
HP Slimline s7527c motherboard needs replacing
yes just what you had stated. remove the card and put in a usb card. it is cheap and easy fix.
Jan 31, 2009 | Computers & Internet
I am running Wondows SP Professional with all the latest updates installed (inc SP3). I have a Sandisk Imagemate 5 in 1 card reader and a Microdia Flashmover. When I put my SD Ultra II 8GB card in either...
Make sure that the Generic USB Device is in the safely remove hardware dialogue then try to install.. or the problem may lie in the face that your usb in not compatible with that specific card...
Jan 07, 2009 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Sep 26, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Quadrant MB-AT-5MVP3 Motherboard Logo
102 people viewed this question
Top Quadrant Computers & Internet Experts
David Payne
David Payne
Are you a Quadrant Computer and Internet Expert? Answer questions, earn points and help others
