Ink cartridges will not move from extreme right to left(to change them)when door is opened
    Genius:
  • 1,250 Answers
Try replacing it with the help of printer cartridge change utility,
Posted on Nov 04, 2008
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Aug 18, 2012 | HP Officejet 6700 Premium E-All-In-One
I just got new ink cartridges for my Dell V305 and it says that there is an alignment problem that can not be automatically fixed. There is no tape on the cartridges. What to do?
Hi
I believe the the carriage of the ink cartridge had jammed. Open the cartridge door and turn off your printer. Move the print head from left to right and from right to left. Close the printer door and try to print again if the error message disappear.
Please let me know if you need more help
Mar 06, 2011 | Dell V305w All-In-One R840635AU InkJet...
Carridge jam error shown but no sign of any blockage
Hi
Try this to remove carriage jammed error. Turn off your printer and open the ink cartridge door. Then use your hand to move the cartridge from left to right and then move it from right to left. I believe the ink cartridge it jammed and needs to use your hand to free it freely.
I will helps you solve your problem.
Regards
Feb 15, 2011 | HP Photosmart A526 photo printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Need to change black ink cartridge in my HP 5610
    Hi
    Power on your printer
    open door at the left of printer
    wait a few seconds until cartridge move at that potiotion
    push down tha right cartridge and pull it out
    do reverse to the new one
    Oct 18, 2010 | HP Officejet 5610 All-In-One InkJet...
    How to change the ink cartridge
    With the power turned on, do the following:
    1. Open the ink cartridge cover (the carriage should move to the right to access if not already there
    2. Pull the lock release levers down
    3. Remove the old cartridge
    4. Remove protective tape from new cartridge
    5. Insert new cartridge
    6. Move lock release levers back up
    7. Close cartridge door (you may hear the carriage move back to the ready position.
    That is the procedure for changing an ink cartridge. Thank you for using Fixya and please remember to return to rate the answer you've just been provided.
    Greg
    Nov 16, 2009 | Brother IntelliFax-2480C Fax
    The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
    Hi:
    If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
    Nov 04, 2009 | HP DeskJet 940c InkJet Printer
    Red warning lights remain on.....
    Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
    Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
    Epson sx 205, can't change the cartridge
    With the power on and the lid up, click on the red stop (left panel). You will notice the cartridges move to the left and then they come back and stop halfway. Afterwards you should be able to slide the cartridges manually with your hand to the larger area on the right where you could do the cartridge change. Once you've moved it to that area just the lift the cover where the arrow is.
    Jan 12, 2009 | Office Equipment & Supplies
    How do I change the ink cartridge in my HP photo smart C3150/ I opened the front cover and there is ink everywhere
    You open the front door and the cartridges will move to the right. Then lift up and pull out the cartridge(s) one at a time. To install reverse the process. Also if you look on the inside of the door, you'll see a little drawing showing you how to change cartridges.
    Nov 30, 2008 | HP Office Equipment & Supplies
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
