Question about HP LaserJet 3030 All-In-One Printer
Print issues My printer does not print properly. My printer prints documents and copies with a darker 2 & 1/2 in" blotch down the middle of the page. and whatever is at the very top of the page shows up very lightly 3 quaters down the page. Please, please, please help!
    Scholar:
  • 78 Answers
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Posted on Nov 19, 2008
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
HP Photosmart 7550--"double vision"
There are known issues if you are not using geniue hp cartridges.
Can you try the printer in another computer to see if its a issue with your computer or a internal printer issue?
Aug 11, 2008 | HP PhotoSmart 7550 InkJet Printer
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
I try to print a card or bank statements and nothing is printing just put in new ink, it only prints the 1st page of a quarter fold card, it should all be on one page and it prints only partial card
IF the Kodak AiO printer is printing partial ther are two main device of the printer that have issue on the scanner [where you put the document for copying] or the printhead of the printer.
Step that you can do
1. Try to print a test page in this way you can check if the printer prints whole page. How to print test page press copy button and photo button on the printer for atleast 10 sec. or until the printer starts printing. Reminder Test page doesn't need a document on the scanner glass. It will print an advertising doc for the printer. Now if the test page is half/partial it is the printhead that has an issue. If it print the whole page it is the scanner that has issue contact kodak for printer repair
2.Clean the printhead twice and reseat the printhead it
How: press menu button then select clean printhead then select basic/deep clean. To reseat printhead open the printer access door; remove the ink cartridges; remove the printhead; close the printer access door then open the printer access door insert the printhead then the ink cartridges.
3. Try to print again [For futher support call Kodak support line at 1 800 421 6699]
Nov 21, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cant copy A4 size
give print...select printer ....goto properties of the printer in the same dielog box.....then ....more page layout options .....there you can change the page scaling
Oct 05, 2009 | Lexmark X4650 InkJet Printer
How to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
Jul 25, 2009 | Ricoh Aficio AP410N Laser Printer
I would like the first page to print first, not last
Access Printing Preferences when a document is not open:
1 In Windows XP, click Start→Control Panel→ Printers and Other Hardware→Printers
and Faxes.
2 Right-click the printer icon, and then select Printing Preferences.
Clear the checkmark in the box next to "print last page first" It is in the middle in the Copies box.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 20, 2009 | Dell 942 All-In-One InkJet Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Lines
I will give you all the reasons I can think of.
1, If the line is only there when running through a document feeder and not there off the glass. The small strip of glass directly under the document feeder is dirty.
2. The drum has a scratch on it, or the cleaning blade is not cleaning the drum properly. Would require that cartridge replacement.
3. The fuser roller may be work in the middle. You would notice some reprinting , or ghost copying if that were bad.
4. Less likely would be some piece of fuzz in the light path, or a small piece of paper or tape in the paper path smearing the ink across the page.
If your machine prints, see if the line is on a print, if its on a print and not on the copy then it is scanner related.
Mar 13, 2008 | Office Equipment & Supplies
Deskjet 895Cse is "sucking" paper in and stalling
Sounds like the printer is getting a bad command from the driver. Try upgrading your driver. Also it may be a bad document. Copy and Paster your text into a new document to see if it clears the corruption.
Sep 28, 2007 | HP DeskJet 895cse InkJet Printer
HP LaserJet 3030 All-In-One Printer Logo
80 people viewed this question
Ben Johnson
