Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore 50554000 stopped working light and compressor
My frige was working today, then without notice, it stopped working completely. The compressing isn't working and the light doesn't turn on. I vacuumed out the coils and nothing happened. Any suggestions...
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
Hi i have a frigidare refrigerator and it is about 5 years old and today it started to kick on and off,, the frige is up to 60 degresse now and the frezzer has completely stopped blowing do you have any...
yes this is very common if your fridge is 5 years old it is out dated just like you are stop being a cry baby ***** and get off ur *** get a job and stop collecting welfare you stupid worthless peice of ****
Apr 03, 2010 | Kenmore Refrigerators
My compressor is running but the frige is not cooling. my fan is working and the coils are clean
YOUR FILTER DRIER IS CLOGGED OR A FREON LEAK. PROBABLY TIME FOR A NEW FRIGE. SORRY
Oct 28, 2009 | Kenmore 57029 Side by Side Refrigerator
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
My frige in not getting cold it just started today the lights are on but its not getting cold i
Do you hear the compressor running? This is a problem with lots of possibles. Things that keep the comp from running, thermostat, defrost timer stuck in defrost, failed electrical components on comp.
If it is running the condenser fan might not be, the coils could be dirty, the light is not turning off when the door is closed (which usually results in a warm frig only, freezer is ok). Eric
Jun 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Not cooling
it could be a thermostat or it could be the relay on the back of the fridge. the relay on the compressor may be bad. pull the fridge out and see if you can feel the compressor. and see if it is hot and if the fan is blowing... if not replace the relay.
Aug 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE side by side gss25lsmf stopped working
it could be a number of things but none of them can be fixed without professional help.
things it could be:
  • bad compressor
  • blockage in the freon line
  • small possibility of a freon leak
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Ge refrigerator compressor
No, Try fiiting a piece of rubber or polestyren under compresser base otherwise compressor needs replacing in any event it will fail eventually rersulting in loss of food contents. Regards Advisor
Aug 30, 2007 | Samsung RS2556 Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
