Question about iLO 3200 32 in. LCD Television
Cant turn on "closed caption when mute" option in new magnovox 42'' LCD.
Followed the TV book instruction manual to a "T" and can't get the closed captions to come on when i mute the sound. TV hooked up to HD/DVR box thru NPG Cable in Arizona. Cable company says this option works thru my TV only, not a cable box option. Tried all the CC1 thru CC4 options, no luck, dont know what else to do.
Model# 42MF438B/F7
  • Anonymous Dec 07, 2008
    sony bravia hdl40s41000
  • joe1silveman Jan 23, 2009
    I can only turn captions on and off with my cable box. I cannot turn the sound on or off. When the captions are on so is the sound.
    I can turn the sound on or off with the TV control and the captions on or off with the cable box control. But I can't turn the sound off and the captions on with either control. I need to use both control to turn the sound off and the captions on. I could do it with my previous cable box.
    My new HDTV cable boxe has a cumbersome interface, and cannot be properly integrated with the TV controls. The cable companies do not provide a 1080p signal so that my 1880p HDTV cannot provide the best picture possible.
5 Suggested Answers
  • 14 Answers
SOURCE: ilo tv.
Another possible solution is to go to a major online supplier of replacement remote controls, such as http://www.remotecontrolscenter.com which offers replacement remotes for the ILO brand. I've ordered from the site above, and you will receive the exact replacement that you need for your tv as I did with my sony dvd player.
Posted on Nov 02, 2007
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
Coldcut
  • 1554 Answers
SOURCE: iLo Tv
I think this is the manual
see page 26
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Posted on Jan 31, 2008
Cybertech
  • 149 Answers
SOURCE: 32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Posted on Apr 07, 2008
  • 14 Answers
well usually you can go to menue or there are button on the remote that say things that you hav eno clue what they mean then keep pushing it till it changes but if its a new tv most likely go to menue and look in the manual
Posted on May 02, 2008
How do i get caption only on mute
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
Aug 19, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
I cant get the captions off the tv?
Go into the menu. There will be closed caption turn on/off option.
Nov 22, 2009 | Dynex DX-L42-10A 42 in. LCD TV
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Can't turn off closed caption & not its not on the TV menu
I went to menu, special features. then select analog CC and selected OFF.
Dec 27, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Closed caption
There is a step-by-step set of instructions in your owner's manual... If you've misplaced it here a link to download it..
Bill
http://books.jvcservice.com/booklist.asp?Model=lt32x506
Dec 15, 2007 | JVC LT-32X506 32 in. LCD Television
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
540 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Radames Pagan
Radames Pagan
loony2ns
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
