Question about Rockford Fosgate Punch 801X Car Audio Amplifier
Blown fuse I was driving around the other day when my bass suddenly cut out. I felt my amp and it felt very warm even though I didn't have it very loud. I got home and checked my wiring fuse and found it was blown. I replaced it and it immediately blew again. I opened up my amp yesterday and was poking around with an ohmmeter. I found very low resistances on all the transistors in one of the channels versus the other channel (i.e. 1 ohm vs. 4.5k), but nothing was burned out. What should I do?
    Scholar:
  • 148 Answers
This can be caused by too low of an impedance from the way the speakers are wired, bad speakers, crossed/shorted speaker wires, and sometimes even a poor charging system (if the amp goes into protect when the volume is turned up) and is usually what the problem is 95% of the time. As you said, very possible to be shorted output devices or shorted power supply rectifiers. Beyond that, it could be a shorted filter cap, some sort of short across the power rails, some sort of short across the output, shorts across the primary. And of course loose hardware - any missing screws or nuts? A loose one under a pc board can short out most anything.
Posted on Nov 02, 2006
I have a 04 Silverado and the stereo always sounded great a lot of bass and clear. I got in one day and it sounds like the bass is off. I assumed it was the factory amp and replaced it and is still the...
could potentially be a blown fuse in your trucks interior fuse box. I had a loose ground connection from mine and i hit a bit bump one time while driving and kept blowing the fuse when the connection would break. maybe worth checking those if u havent already
May 25, 2014 | Car Audio & Video
Tip
I replaced the valve prematurely! Check the power to the valve FIRST! My had no...
Your washing machine will not fill up with water. You have checked the hoses, cleaned the screens, and still no water. Now what is next?
First make sure that you unplug the washer to prevent a shock. Then you will have to get to the valve. For some washer this can be done by an opening in the back panel. And for other you may have to remove the entire top of the washer to access the valve body.
Hopefully you can get there without removing the wiring, so that you can check to see if you are getting power to the valves. Once you can get to the valve body, then carefully get a meter on the connection to the coils, then plug in the washer and start the cycle where the water would normally flow. If you have power at the coil and the water does not flow then you know that the coil is bad or the valve is stuck. There are ways to clean the valves but usually a new valve body will be under $40.00 and it is not worth the mess and the possibility that the valve will soon get stuck again. If you find the problem there, just replace the valve, it is much easier.
If you are getting no power to your valve then you know to look back in the wiring further. You may have a bad switch in the timer. Follow the wires and trace the back to see where the power is stopping at. If you have power going to the timer and no power coming out then you have found your problem there.
Troubleshooting appliances is often just a matter of following the problem back to where it starts. Be patient and be very careful when working with electricity. Always make sure you have the appliance unplugged when you are not actually checking for voltage. Also be aware that some appliances have power on what you would think to be the neutral.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
on Jul 04, 2011 | Washing Machines
Reset (replace) computer box
The fact that all your electrics disappeared including all dashboard lights indicates a faulty battery/connection.
Check the battery terminals for cleanliness and tightness. Check the black earth lead for cleanliness and tightness where it connects to the engine block/bodywork. Try adding an extra black battery lead - connect it to a suitable point on the engine or bodywork
Mar 26, 2017 | Opel Astra Cars & Trucks
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Active sub has stopped working
I have 2 12" kenwood speakers on a 1000 watt amp ... the other day they cut off but the speakers arent blown, i replaced every fuse in the amp and the amp still cuts on when i turn the car on, yet the amp seems to not be pushing the speakers ...i also looked at the main fuse under the hood of my car but i cant tell whether its blown or not, why is my amp not pushing out any power?
Mar 31, 2009 | Audio Players & Recorders
No Power to the Amp
open the amp and look for a fuse either on a circuit board or on wires inside. trace power wires onto board.
Sep 04, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Rockford Fosgate Punch 801X Car Audio Amplifier Logo
102 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
