Question about Amana D530M Dehumidifier
Amana D530M Dehumidifier won't run
This humidifier one year old, was working fine, just stopped working. No lites, no fan or compressor run. Have 120 volts at circuit bd. fuse, fuse is OK. Tank switch OK, humidistat OK, My guess is the circuit board is defective. It has these numbers on it:
2014303/EC
02514-210
Is this circuit board available? Cost?
Thanks,
Jerry
  • Stt488 Nov 19, 2008
    I have the same problem. Everything tests out ok except the circut borard. I need a new one but can not see to locate one.
  • s gray Jan 05, 2009
    Same Problem. Was working fine and just stopped. No lights, nothing???
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Posted on Feb 27, 2009
My stupid Amana D530M died as well, maybe 18 months old. The control board appeared to be the problem. (Like everyone elses) Amana sucks. I will never select Amana anything again, unless they start to sell beer.
I can't find a replacement board, so I wired the blower and compressor leads to the fuse, and then back to the main power lead, bypassing all of the control board functions.
Basically, you plug it in, and it runs fine, fan hi/lo speed still works.
There is no full tank sensor as well, obviously. So, I hooked a hose up, right to my floor drain.
I am not recommending anyone does this, just sharing what I did. I didn't want to haul this to the landfill, until it's dead.
Posted on Aug 01, 2010
Solution is very simple . Don't buy any of these Amana units . I had three of them . One lasted 1 year the other two 2 years in the D545m model . These things are cheap but they are junk!!!!!!!!!!!!
7/2/10
Posted on Jul 02, 2010
Hello, I need to know where the fuse on amana d530m dehumidifie.
Thanks
Posted on Sep 08, 2009
  • rrogers25 Jan 06, 2011
    My amana D530M would not run. Plugged it in and nothing. Found a blown fuse on circuit board (12 amp slow type). Fuse was under a opaque plastic cover. Having difficult time finding replacement fuse.
4-5 years old. Has work great all that time. In the past week it stop collecting water. It runs but never any water in it. It's not leaking out. The collection pail is dry as a bone.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 23, 2011 | Amana D530M Dehumidifier
The dehumidifier runs but does not remove moisture. The coils are cold but no frost. The inner coil is hot.
heatman101
May 17, 2011 | Amana D530M Dehumidifier
We can hear the fan running and then the compressor, but little to not water produced; sometimes we can hear it click on and then off; the fan seems to be running a lot...
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has
and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
Hope this helped you. Please let me know. Thanks.
May 17, 2011 | Amana D545M Dehumidifier
My humidifier has stopped dehumidifying while the unit itself is running. It simply does not take the water out of the air even though the motor is running, sensing the humidity of the basement. Is this...
heatman101
Apr 23, 2011 | Whirlpool AD50USL Dehumidifier
+unit will not start.
heatman101
Feb 05, 2011 | Amana D530M Dehumidifier
Ijust bought a danby dehumidifier ddr5009. The compressor works fine but the fan never stops running. Even if I set the timer on standby.
This dehumidifier is built in such a way that the fan runs all the time;however the compressor works only when it is needed. These infos are not specified in the booklet. It does not work like the old ones.
Sep 10, 2009 | Danby Dehumidifiers
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
Fan runs, but compressor does not start
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Amana D530M Dehumidifier Logo
973 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
