Question about Refrigerators
Frigidaire- Freezer side is defrosting
The freezer door wouldn't seal shut tight, then noticed a few hours later that things were melting/defrosting in there. Checked coils and they've been cleaned about 6 weeks ago, so not too dirty. Wonder what the problem could be? Compressor going out?
  • oompaloompa7 Nov 05, 2008
    Now the compressor is running again, but the freezer door wants to keep bouncing open. All the seals are normal like when we first purchased it. So if you close the refrigerator door, the freezer door will bounce open slightly. It use to seal itself shut and NEVER bounce open. Any suggestions would be appreciated. Thanks.
    President:
  • 1,462 Answers
If door not sealing then air gets in and the moisture in the air freezes on the evaporator and blocks air flow. fault may well cure itself after a few days assuming the door is now sealing ok
Posted on Nov 04, 2008
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
A few days ago I noticed that the bottom of my freezer side of the fridge was covered in about 1/2 inch of ice. It goes all the way from the back of the freezer up to where the door seals...and the door...
its not doing a defrost by itself you need to replace the defrost heater/defrost termination sensor/thermostat/defrost timer could be any one of these parts causing this problem you need to test each part with a multi-meter to determine what needs replacing.
Jan 11, 2011 | GE GSH25SGRSS Stainless Steel Side by Side...
I have a Frigidaire PLHS67EEsb7 side by side. Every couple of months, something happens that causes the coils in the freezer to freeze over and the fridge and freezer stop cooling altogether. I have to...
clean out all the vents,syringe the drain holes with clorine bleach,check the door seals for air tightness all round...after a full defrost(do not help it with a hairdryer as this only defrost the ice you can see....try to defrost it when you can leave it for 24/36 hours....with the doors open and switched off....then dry thoroughly.
Jul 20, 2010 | Frigidaire PLHS67EESB Side by Side...
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer freezes over and runs continualy
The number one cause of freezers frosting up and especially that fast, would be that moisture is getting in.  The cause of this is more than likely that your magnetic seal around the door is not making a tight seal.  Check around the door and make sure it is sealed tight.  Even the smallest of gaps will make a big difference.  More than likely it is leaking on the side that has the most frost.  Hope this helps.
Mar 12, 2009 | Amana ABB1927DE Bottom Freezer...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
