Question about Samsung CXD2512 25 in. Combo
Can I play the video and a dvd without the remote control?
My remote control is not working. The batteries are new and it still doesn't work. I would like to use the video player and a DVD player in the meantime, but I can not seem to change the channel to 4 or if there is an input channel to view videos or DVDs. I have tried configuring the cable remote to work with the TV but that proved futile. I also tried the DVD player remote, which was also futile.
  • Rowenna May 11, 2010
    Thank you very much for this solution. It works!!!!
Sorry I mean to thank you not to clarify or post a solution. Thank you!
Posted on May 04, 2008
    Sergeant:
  • 337 Answers
Your set should have external video and audio imput jacks besides the tuner imput for antenna,you can use the video and audio outputs from the vcr or DVD and conect them to the video and audio imputs in the tv then you can select a channel below 1 or push the switch that says Video/antenna.
Posted on Oct 02, 2006
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    The remote doesn't work for any of the DVD functions.
    1 replace the old batteries use new ones alkalines with the same mark and polarities.
    2) clean the contacts batteries with c. cleaner.
    3) open the remote control, and clean the keypads from dirty, oxide, corrosion, with c. cleaner.
    4 Proceed again, if the problem persist, you must go to the repair shop TV or replace by new ones.
    God bless you
    Nov 11, 2012 | Televison & Video
    Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
    1) the batteries will be the same type and full charged
    2) clean the contacts battery from dirty, dust, oxide or corrosion
    3) retight the spring contacts battery with pliers for a GOOD contacts
    4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
    see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
    God bless you
    Jul 31, 2012 | Toshiba Televison & Video
    My Maestro IR remote no longer works after 10 years
    The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
    If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
    Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
    Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
    Apr 13, 2012 | Electrical Supplies
    I have a Digihome 19LCDVD911 TV and the remote will not work in DVD mode, why is that?
    do not know here but iam surmising that you have to go into menu and select DVD play then it should work ? maybe
    Dec 26, 2011 | Televison & Video
    My remote control will not work at all help? I went a long time without using my dvd player and the remote use to work just fine however i tried putting in new batteries ive went online to get codes for...
    Check the leads of the remote where the batteries are inserted. Sometimes the leads corrode that causes a non-contact. Scratch it using a smooth sandpaper or even a utility knife to erase the corroded part.
    Hope it will work.
    Thanks for using fixya...
    Jan 16, 2011 | Durabrand DVD-1002 DVD Player
    Re: Panasonic Remote Control for DMR-ES35V
    All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
    Jun 25, 2008 | Panasonic DMR-ES35VS
    My remote does not work
    Reset remote. If universal remote, put on dvd mode.
    • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
    • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
    • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
    • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
    Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
    Jun 12, 2008 | Cyberhome CH-DVD 300 DVD Player
    Input Selection without a Remote
    On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
    May 24, 2008 | RCA F27442 27" TV
    Dvd will not play
    Hi there. If i understand correctly, you do have the official microsoft DVD dongle and remote ? If so, you might wanna see if the remote is defective. Do you have a camcorder at home ? There is a trick to see if a remote sends it's infrared signals. Put the camcorder on, in a dark room, and put the IR transmitter on the top of the remote in front of the camera. You'll see the IR remote transmitter blinking if you press some buttons. Human eyes can't see it, but the camera does! Try it with another remote that you're sure that works, you'll see. If the microsoft xbox remote doesn't do anything, check batteries, else it's proably defect. If you like to tinker a bit with things, you might wanna open it up to check if there's any cold solder point on it (a broken connection), but you need soldering skills to do so. Else, you'll need a new remote. Hope that helps ! cheebster.
    Jul 03, 2007 | Microsoft Xbox Console
    Samsung CXD2512 25 in. Combo Logo
    324 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
