Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Ice maker is not making ice, any ideas?
My ice maker is not making ice, any ideas? I do not see any obstruction with the water line.
  • rasully Nov 11, 2008
    I have the same model approximately three years old, and mine stop making ice the same day you posted your problem. I inspected the unit and found the ice stripper and control module broken. After a crash course in learning how to diagnose, I determined they broke because the ice cube mold heater stopped working. After adding up the $$ of the replacement parts, it's was cheaper to order a whole new assembly.
  • ccb913 Dec 21, 2008
    The ice maker won't make ice, infared light blinking, I have lost the manual, I need held to solve this problem. Thanks
  • 148 Answers
Check the water inlet valve it is usually the culprit.
Posted on Nov 11, 2008
    Sergeant:
    Champion:
  • 324 Answers
Might be the module.this controls the icemaker
Posted on Nov 04, 2008
Every time ice maker runs, water accumulates at the bottom of the fridge. It is a bottom freezer model made 9-2013. What could be plugged?
Check the ice maker fill cup, it could be full of water or ice and all the water misses the ice maker. Check the fill line in the freezer to make sure its in the full cup to the ice maker. CHeck the drain under the evaporator in the freezer to see if it is open and obstructed. Thats what I would look for. Good Luck
Apr 20, 2016 | Refrigerators
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Icemaker makes lil ice cubes now could this mean the line is clogged?
Would not expect you to ask this question but yes you are right cajunboudoin, an obstructed water line by either a defective water control valve, water filter beyond its useful life or a crimped water supply line will cause the ice cubes to be small during drop of ice cubes into ice bin. Fact is with Whirlpool the water valve is set to remain open filling ice maker for around 7 seconds. If water is moving slow filling the time will be to slow for the flow, If anyone has a good question you do but I would always want everyone to provide their model number, Click Here=> Whirlpool Ice Maker Troubleshooting Thanks Sea Breeze
May 06, 2012 | Maytag Refrigerators
Maytag side by side refrigerator with freezer on the bottom water is spraying everywhere when the ice machine comes on. It has the ice / water dispenser on the front. Any ideas?
Check the water line leading to the ice maker for kinks. Also check the filer and ice tray end of the waterline for obstructions or ice that might be deflecting the water to areas other than the ice tray. Let me know how you make out. :^)
May 01, 2012 | Maytag Refrigerators
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water lines i think are ok but cant get water or make ice
Check the following:
See if the fridge has a water filter...it could be plugged and need replacement...check your manual for the location and replacement procedures
Check the inlet water line to the ice maker...it could be frozen...a hair dryer can be used to thaw it out and get the ice make to work again...be careful and don't overheat the ice maker inlet water line.
Make sure the water line is ok and not obstructed or kinked
Check the ice maker water valve to be sure it opens and isn't clogged
Cycle the arm on the ice maker and wait to see if it will make ice again
Jul 05, 2009 | GE Refrigerators
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
150 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
