Question about Tappan 18 in. MDR251RE Built-in Dishwasher
Beatstherest again Thank you for helping me with question on dishwasher install...Water seems to be ok. Electrical connections seem ok. What is the electrical part on the valve that you mentioned? Does this control the water flow?
    President:
  • Tappan Master
  • 2,651 Answers
Well if the wire connection/leads arent fully connected to the valve its possible the valve would not energize. (2 wires leading to the valve in which oyou hooke up water supply) perhaps came loose in shipping/delivery
Posted on Nov 04, 2008
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
We have just taken delivery of a Siemens SN26M230 dishwasher and have connected it to the water supply. However, no water seems to be flowing into the machine, which has an 'Aqua stop'. There is no...
Make sure water is turned on. Make sure you have electrical power. You can try pouring a quart of water in it to help prime the pump. The water supply line to the dishwasher could have been bent and cut off water while installing the dishwasher.
Your question got my interest I have no dishwasher. My wife wants a dishwasher I told her I have had one for 33 years. She did not take it that well.
Aug 12, 2017 | Dishwashers
My dishwasher doesnt seem to turn on to a cleaning cycle. barely any water is in there and it smells like it is burning sometimes. my water is on to the dishwasher. also water comes out of the valve in the...
Check your disposal. If newly installed the knock out plug was not removed. The smell could be food decaying. No water should be coming out of the vent on the sink.
Remove the rubber pipe from the dishwasher to the disposal.
Stick a screwdriver into the hole and look down the disposal from the top and see if you are able to see the screwdriver.
If not get a hammer and pop the plug out and reach in the disposal with your hand and retrieve the plug after you have unplugged the electrical cord.
Once the plug is out re-install the rubber pipe and secure it plug in your electrical cord and try your dishwasher again. Good Luck
Jan 07, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
Had new kitchen so just re connected my dishwasher. Warning light to check water has come on. hoses and water going into machine seems ok but machine seems to be slow at filling. looked at filters in case...
I would remove the water line going to the dishwasher and let it run into a bucket. Sometimes on older shut off valves when you shut them off and try to turn them back on they get gunked up or dont open all the way. If you have good water pressure to the dishwasher then I would try replacing the inlet valve on the DW. Hope this helps.
_MJ_
Dec 15, 2010 | Bosch Dishwashers
We have an ariston LS 620A dishwasher. For the last year every few months the dishwasher seems to cause a short in our electrical box causing all the power to go out in our house. It is only when the...
The problem seems to be water seepage into the electrical contact.
If the heater has lost its insulation this problem could accur
( element to body )
Disconnect the heater and give a try without any load and soap. If it
performs OK , you have to check the heater by removing from the
machine. Mainly I suspect water seepage into the electrical system.
Aug 30, 2010 | Ariston Technologies Dishwashers
Is it OK to attach a hot water feed rather than cold water.
All dishwashers are suppossed to be connected to hot water. Who connected yours to cold water and why? Doesn't make any sense. Definately change it over to hot water feed.
May 14, 2009 | Asko D1716 Built-in Dishwasher
Whirlpool dishwasher
Hi jamesward,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher turns on and you can hear the motor but there doesnt seem to be any water going in
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Dishwashers
No water after new installation
Start the unit and let it run for 30-60 seconds to allow the sensors to detect water. The unit should start. If not, Loosen the water line at the valve and check for water. If there is water. the next step is to unplug the water valve electrical connection and check for voltage across the terminals. If there is power, change the valve. No power, the circuit card is suspect.
Dec 02, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher
in some cases it is the water metering tank on the left hand side that gets bunged up and needs cleaning, next is the water feeding pipes. if everything is clean and the water valve supply is ok then it will need a special mod kit to be fitted, which will need to be fitted by a pro. tony.
Jun 12, 2007 | Zanussi 32 in. DE6755 Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
46 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
