Using the codes you can unlock your samsung mobile because its safe for your mobile....... Get the unlock code for your samsung SGH-I700 model mobile from this site Superunlockcodes.com , here it gives the code along with easy instructions for your mobile......
For sure your mobile was previously programmed or update using a gsm gadget,bring it back to the person who fix your phone before, the IMEI number should be fix. you'll might getting some network or simlock problem if you change any simcard.
>>make sure that your phone is set up with your pc, and recognized as a modem, i;e ; sgh-l700 samsung mobile modem. and you have set up your mobile phone for internet connection. it can be seen in the network folder. now try these. 1. check your phone if it can connect to web through your internet phone browser,just select from the menu of your phone, internet, select home, if it can connect and it open to its home page, then you are really set up for your connection. 2. open your control panel, select phone and modem options, you will see your samsung mobile phone there., select properties, select advance and enter this '' extra initialization command AT+CGDCONT=1,"IP","celloneportal" 3. select apply and ok, and close your control panel. 4. open your network folder, select your samsung mobile modem,right click it and select connect. 5. try to check.
