Question about Frigidaire GLTF2940ES Front Load Washer
Power is on but wont wash or anything only hums when i press start
I was washing just fine when i went to take out a load and it was soaking wet. I took out the laundry to lessen the load with no success it still only buzzes when i press start why i checked the breakers and the power it is on because the lights turn on but it wont run Help im stumped
  • mt314 Nov 07, 2008
    I have the same problem. Press start and it only hums or very soft buzz. Removed drain hose from pump and squeezed black rubber bag ??? and water flowed through pump just fine. Was able to drain hose and it is clear. With unit on drain/spin cycle with drain hose off, sometimes the pump runs for about 3 seconds, no water come out, then stops and only the hum from something other than pump continues. Could this be the motor controller? Unit is only two years old.
  • 3 Answers
You may need a motor controller, which is covered under the warranty, but of course you have to pay for labor and diagnostic which means you pay...
If you're handy go buy the controller, many sources, and put it in. It will cost you around $139, but if you use the warranty it will cost you around $250....labor and diagnostics.
Posted on Nov 04, 2008
    President:
  • Frigidaire Master
  • 2,651 Answers
The buzz or hmmm noise is probably coming form a clogged drain pump assy, something has gotten into it and is preventing normal operation. youll need to remove the lower acess panel (2 screws aong hte bottom of the front of unit) from there youll gain acess to the drain pump in the rught front corner, pull off the hoses and check for obstructions, even look within the white pump impeller housin gas well. UNPLUG UNIT FIRST!!!!ALWAYS LIVE WIRES TO DRAIN PUMP ASSY
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't spin
When washing does the unit rotate in both directions ? If NO, the problem (likely) is the motor/brushes. If YES, insure you're not overloading or using non-HE detergent or more commonly refered to as "regular" detergent/soap. (soap is a very bad thing for these front load units).
Sep 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Mar 05, 2008 | Washing Machines
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
