Question about Pioneer Audio Players & Recorders
I have a Pioneer Elite VSX-80TXV My front left channel is quiter and has significantly less midrange and bass than my other channels. The EQ's are on the factory settings but the channels are not equal. I also test the speaker and when they are switched the problem remains the same for both speakers. I tripled checked all wiring connections and have no problems there.
The problem was actually at the speaker. The speaker I was using was a Kef speaker and it was missing a metal bar running across both negative terminals in order to power both the tweeter and woofer.
Posted on Nov 04, 2008
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Can i hook up a eq to my pioneer VSX-D457 digital processor ?
Your unnamed EQ can probabaly work with the VSX if it attaches in the traditional Tape Loop fashion (outs to ins) BUT...
It will only work for 2-channel analog source material. Activation of a tape loop on a modern AVR disables all digital sources. But you will still be able to apply DSP to the sound coming through the EQ as you would with any other analog source.
Jul 19, 2011 | Audio Players & Recorders
I don't understand how to use the 'tone' controls
Watch vidoes on "mixer setup". Don't worry if they are not your exact model as the principles are essentially the same among the various types. EQ controls for the channels are "flat" when they are all set to 1 o'clock. The lower one reduces or boosts the bass, the next the midrange and the high the trebles. SOme have a midrange EQ frequency which adjusts the cnterpoint of the midrange frequency. Leave this at 12 o'clock until you get familiar with the rest if your unit happens to have that extra control.
Jun 05, 2011 | Phonic Powerpod K12 Plus 1000W 8...
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
I have a pioneer elite vsx-03txh reciever and all my speaker indicators light up except for the subwoofer but my sub still works and all my other speaker channels light up for 5.1, 6.1 and 7.1 but not the...
And the problem is? Your receiver setup determines what gets sent to the sub from ANY source.
The indicators are to inform you of how many channels are encoded into the digital source. If a source-dependent LFE channel is encoded, it should light up. Check the source's setup to make sure it knows you have a sub and is configured for a discrete LFE channel.
Feb 12, 2010 | Pioneer Elite VSX-03TXH Receiver
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
Pioneer DJM500 Mixer - Bass EQ Control on Channel 2
You might want to clean the exisiting potentiometer with dielectric solvent. This might work without having to replace the Pot. But if you have to replace it, make sure you have the correct tools. This is a fine soldering job, but it appears you have the correct part.
Apr 07, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
How to connect 901 equalizer to a Pioneer VSX 47TX
I have a VSX-36TX so this is how it's going to work...
You will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the VSX 47TX doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Jan 24, 2009 | Bose 901 VI Main / Stereo Speaker
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
