Question about AEG Lavamat Lavalogic 1600 Front Load Washer
Door not unlocking
We have a computerised AEG 1600 washing machine and the door will not unlock after the wash - tried everything including turning on and off, putting it on another full cycle, and leaving overnight. The first time it happened it un-locked overnight on its own. What is the problem?
The way we were able to open the washer door was to run a short cycle with no spin. If you open the filter door, BEWARE when turning the filter knob (?), as WATER LEAKED OUT QUICKLY. Put down towels before doing this.
Posted on Jul 16, 2008
Hi i have a problem with Lavamat Lavalogic 1600 Front Load Washer error cade cf 429467295
Posted on Mar 18, 2008
    Problem Solver:
  • 8 Answers
Open the filter door at bottom turn screw with coin , door should open ,
Posted on Jun 07, 2007
SOURCE:
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Require a user manual for a LAVAMAT 1000 to download
Hello I need to number kushintës Lavalogic AEG 1600 washing machine
Feb 07, 2011 | AEG Lavamat Lavalogic 1600 Front Load...
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
Have an AEG Lavamat 88800 washing machine. Problem is that getting a build of a brown sticky residue in the rubber seal araound the door, which then gets on the clothes being washed! 9it is not mould - I...
You are using a cleansing agent that has no biological cleaning agents so it does not clean off all the organic debris.
All very well for those with sensitive skin but not for the machine.
Try lemon juice to de grease the boot.
Aug 03, 2017 | AEG Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
760 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
