Question about Texas Instruments TI-86 Calculator
Repeating decimals into fractions
_
1.) 4.5
__
2.) 0.32
On the home page put 4.5 and press enter. Then hit "2nd" and "x" to get the "Math" window up. After that hit F5(Misc). Then hit "More". Finally, hit F1(Frac) and press enter. You should get the number (9/2). Repeat the same steps for 0.32.
Posted on Nov 06, 2008
SOURCE: fractions appear when I divide; not decimals
press 'yellow key' then press 'enter' to see answers in decimal format instead of fractions
Posted on Sep 10, 2008
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
Typus
  • 69 Answers
SOURCE: decimals to fractions
press [Math] [ENTER] [ENTER]
Posted on May 12, 2009
  • 41 Answers
SOURCE: changing fractions to decimals
pressing the 'a b/c' key toggles between fraction and decimal formats
Posted on Sep 15, 2009
  • 7993 Answers
Use the [2nd][MATH] keys. Scroll right [F6] to the softmenu [->Frac or To Frac].
Hope it helps.
Posted on Sep 23, 2009
Which is more precise, fractions or decimals??
Fractions can be more precise than decimals. For example: 1/3 can not be expressed exactly as a decimal. .33333333333333333333333333333333333333333... is only an approximation.
Some numbers cannot be expressed precisely as either a fraction or a decimal. pi is an example.
Jan 04, 2017 | Homework
How i fad the one decimal place the answer of this question 0.7844 correct to 1 decimal place
You haven't made the purpose of the question very clear Miriam so I am only guessing that it is an exercise in rounding or shortening decimal fractions to make them easier to work with which is often convenient when approximations do not matter.
The general rule of rounding is to take the last figure and if it is less than 5 it is erased and if it is 5 or more it is erased but 1 is added to the next or the new last figure and the process is repeated until the fraction is shortened to the required length.
If you take the decimal fraction 0.8745, after the first stage of rounding it would become 0.875 and then after the second stage of rounding it would become 0.88 and then finally rounding to one decimal place the result would be 0.9.
I hope this helps you deal with your fraction. I apologise in advance if I have misunderstood the question.
Mar 01, 2015 | Office Equipment & Supplies
If i got a repeating decimal what do I do
You can keep a certain number of decimal digits and ignore the others, or you can use the original ratio (fraction) because it is exact.
Dec 16, 2014 | Office Equipment & Supplies
What is the fraction 5/9 as a decimal?
0.5 repeat, that is 0.5 followed by an endless string of 5's. Normally this is written as 0.5 with a heavy dot over the 5, but I can't do that here.
Oct 01, 2014 | The Learning Company Achieve! Math &...
Two repeating decimals equivalent to a fraction with the denominator 10
A number with a periodic decimal representation cannot be equivalent to a fraction with denominator 10 (or a multiple of 10) except if the repeating decimals are zeros.
0.454545...=45/99=5/11
Sep 04, 2013 | Super Tutor Pre Algebra (ESDPALG)
Convert .714285 to the fraction 5/7?
Say you have a repeating decimal number 0.714285 714285 714285 etc. You identify the period (the repeating part) and in this case it is 714285.
Y
ou count the number of decimal places in the period: here it is 6. Your equivalent fraction is
Fraction= period/(99...9) where the number of 9's in the denominator is equal to the number of decimal places in the period. For this case, that is 6.
Thus
0.714285 714285 714285 etc.= 714285 / 999999
Reduce the fraction and you will find 5/7
This technique works for a repeating decimal number where the period starts just after the decimal mark.
If the periodic part does not start right after the decimal mark there are modifications to be made.
Jan 16, 2011 | Office Equipment & Supplies
0.32 repeation decimal into a fraction
You can convert a decimal value to a fraction by using the >FRAC command in the MATH MISC menu. Be aware that this command will not work on all values.
Oct 26, 2010 | Texas Instruments TI-86 Calculator
How do i convert 1.695652174 on TI-84 plus edition. i already try doing math key but it won't convert into fraction and keeps giving me same answer.
Answer is 39 over 23......or 1 and 16/23. Check your settings on the calculator. People are running into this problem with decimals and there is an easy fix.
Let's say you have a repeating decimal such as .16666.....If you type in .166 or .1666 or .16666 and check as fraction it will NOT work. Reason why is you haven't typed enough of the "repeating" numbers for the calculator to understand that it is in fact "repeating." If you have a single number ie. 1-9 you must type in a minimum of 11 of that number. Then it WILL work as fraction.
Let's say you have a 2-digit number such as 13. Then you need to type in at least 6 of that number. Say you want to convert 1.2181818 where 18 keeps "repeating." Well I only typed it in 3 times. It won't work to convert. But type in that repeating number 6 times and it will.
Again calculator need to know that it is in fact repeating. Only typing it in a couple times could still change the outcome so it will basically fail to show the fraction until it knows for sure.
Sep 14, 2010 | Casio FX-115ES Scientific Calculator
Multiplication error(?) with repeating decimal place fractions.
You may have guessed right. The presence of the parentheses makes the content of the parentheses evaluated first. So there is a loss of precision.
On the Ti92 I do 7*(-1/7)+1 and find 0.
But with Floating mode set at 12 decimal digits I get
1/7.=.142857142857.
Then .142857142857.*(-7) + 1 gives 2E-14.
Try to calculate pi*(-1/pi) +1 or e*(1/e)+1.
Hope it answers your question.
Sep 29, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
564 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
