Question about IBM ThinkPad T23 2647 Notebook
How can i format my new harddrive?
I`v installed a new 60gig hitachi harddrive on my old T23 and all i can get is a the same PXE-E61:media test failure
PXE-MOF screen?
I have changed the boot to cd rom first,and it doesn`t change anything.
i have reset the bios to default.
And still nothing but the same screen.
The hard drive is a HTS721060G9AT00 and on the bios it has a -(PM) after it.
I am trying to use windows xp pro.And yes it is a legal version!!!
The laptop works fine with the old harddrive in it.(the old harddrive crashes every now and then.That`s why i am swaping it out.
Help
    Master:
    Sergeant:
  • 461 Answers
You have to make sure the HD is properly formated and install the XP into it... you may want to read below link which i think might be helpful to solve you problem...
http://etech.maiila.com/boot-failure-system-halted
good luck...
Posted on Nov 04, 2008
  • IBM Master
  • 4,338 Answers
When the unit gives the booting from PXE, it means that the hard drive is not being seen. First, check that the jumpers on the drive are set for master.
According to Hitachi's website, the drive is set as Master, no jumpers from the factory.
Setting 1—Device 0 (Master) (no jumper is used)
Setting 2—Device 1 (Slave)
Setting 3—Cable Select
Setting 4—Do not attach a jumper here
Setting 5—Do not attach a jumper here
The default setting at shipment is Setting 1 (no jumper)
If the drive is set correctly, I would suspect that there is something wrong with the drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Computer wont boot error code pxe e61
You must initialize the new hard drive first.
Jan 28, 2014 | Toshiba Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Please I have a question in relation to my acer aspire laptop5536-5883, when i switch on my laptop, it says PXE-E61: Media test failure, check cable, PXE-MOF: existing broadcomm PXE ROM. OPERATING SYSTEM...
PXE is looking for an OS on/over a network...you need to tell the PC to boot from your harddrive or CD...if the harddrive is bad/blank you need to (re)install windows...
Feb 14, 2011 | Acer Computers & Internet
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
My laptop says a disk red error occurred and will not boot up it goes in circles asking for restarts and says the same thing also iam getting this message as well PXE-E61 MEDIA TEST FAILURE CHECK...
"PXE-E61 MEDIA TEST FAILURE CHECK CABLE"
This means that the motherboard and harddrive are not communicating correctly, there is no data cable to connect the harddrive to the motherboard on a laptop the harddrive connecting plug is soldered directly to the the motherboard.
Either your harddrive is dying, or your motherboard has gone faulty. Laptop repairs are quite involved, if you are not familiar with taking laptops apart I would suggest you get profesional help with this problem.
If you want to have a go yourself I can point you in the direction of websites I use when doing laptop repairs.
Sep 10, 2008 | Computers & Internet
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
IBM ThinkPad T23 2647 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
