Question about Kenmore 44072 Front Load Washer
Machine out of balance. tub pulled off the rubber seal between the tub and the front panel. looks like one of the "shocks" under the tub is all the way compressed. the one on the right looks to still be supporting some of the load. what do yo uthink the problem is?
  • santostrabal Nov 30, 2008
    I have a similar problem it makes noise when in high spin like a loud clunk however after taking the top & bottom lid off I didnt notice anything out of the ordinary. what I did notice is that When i grab the stainless drum inside the washer by ther ears inside there is for and aft movement as if the bolt has become loose but when I tried to tighten it it is already tight......any ideas what else I can do
Actually got the new shock absorbers in the mail and noticed they don't come "pre loaded" or "extended". so i go to thinking they must not be true shock absorbers more so just "dampners".
after further review (and a with a mirror on the left side of the tub) I noticed a short, but beefy sized spring near the top of the tub that was connected to, what appears to be the framing inside the washer, but not connected to anything else. I'm assuming this spring is actually what holds the weight of the tub and the "shock absorbers" on the bottom only dampen the "motion".
SO, now my challenge is how to get inside and re-hook the currently "unemployed" spring on the left side. (which would explain why the tub 'hangs' to the right as the right spring must still be doing its job).
any ideas on how to remove the front panel on the machine without breaking every plastic tab that is holding it on??
or do i need to approach this issue from the rear?
Posted on Nov 13, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
You see the problem right there, id replace the shock absorbers,and change both for the other has been taken on extra stress levels, unable to look up part number for you with incomplete model number, but def a job you can do yourself
Posted on Nov 04, 2008
Why does my washer make extremely loud noise on spin and looks like the drum has fallen down?
It sounds as if something mechanically serious happened. Call a repairman and get a diagnosis. It may be a simple repair, but it is more likely to be a difficult and costly one. You have to decide.
Feb 23, 2015 | Maytag Neptune MAH5500B Front Load Washer
After 23 years of good service the drum has fallen off at one side. Is it worth fixing or buy a new one?
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Jan 28, 2014 | Asko W6221 Front Load Washer
Washer will not stay balanced
The washer balance is mostly controlled by two factors:
  1. Balance of the appliance cabinet (shell)
  2. Suspension of the tub inside the cabinet.
As far as the cabinet is concerned, balance, level, and plumb are determined by the adjustable feet. Installers usually come in with a level and test the level (side to side parallel to ground) and plumb (front to back perpendicular to groud). Many times they overlook the corner to corner balance. I think corner to corner is more important than being plumb or level. Try adjusting.
If that doesn't solve your problem, you may want to check the tub suspension. There are shock absorbers beneath the tub that push in opposite directions to keep the tub balanced in the cabinet. You can access them by removing the front access panel (diagram below -- remove 3 screws and pull out from the bottom to let it fall down)
You will see the shock absorbers in plain view. Wiggle the tub around to see if one is any weaker than the others. If so, replace it.
If you find this advice helpful, please rate me as I am trying to obtain the "Guru" status so I can offer premium support.
Thanks,
Chris
Apr 03, 2011 | General Electric WCVH6800J Front Load...
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
We leveled our machine,but when we run the cycle, it begins to rattle and slams against the wall
Thanks,
Chris
Feb 19, 2010 | General Electric WCVH6800J Front Load...
Drum out of balance
The top panel should lift back on hinges after you free the front clips. Make sure you do not have to loosen any screws under the lid as some models are different. You can use a small wood wedge to gently pry up the top panel so you do not scratch the enamel paint. Once you lift the panel back you can inspect the arms which support the tub and easily replace the defective support or rubber shock absorber.
Sep 10, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water leaking
it could be the boot seal, (rubber piece that joins the tub to the front panel). the boot can get a hole in it or it can pull away from the tub if the clamp loosens. if it is the front of the outer tub that is cracked the manufacture did warranty the tub for ten years prior to 2006. check your owners manual as that is what the company has to honor. they only cover the part not labor, and in the usa only. i hope this helps.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore 44072 Front Load Washer Logo
316 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
