Working on Gateway MX6454 when battery was getting low. Went to plug electrical cord to AC pin of computer. When plugging the cord to the laptop there were sparks coming from the laptop electrical pin when the connection was made.
  • 128 Answers
Have your adapter checked it may be faulty. BTW, the dc pin of the adapter is the one that plugs to your laptop.
Posted on Nov 04, 2008
Why did my battery stop working after i removed it from laptop?
Sounds like a bad battery.try putting it back in and plug in charger.batteries may just be to low to boot computer.If it will not charge than your plug cord is shot.
Sep 18, 2014 | Gateway NE56R13u Laptop
No Power
Your laptop's power jack may be broken, which is why your laptop doesn't charge your battery at all, which is why it won't turn on now. I would take a look to make sure that the power supply is good, the battery is good, and then see if the power LED is even coming on when you plug the laptop to a power source.
Apr 10, 2013 | Gateway Computers & Internet
Can i use this lap top with plug in and not a battery?? where is the plug in?
I BELIEVE so. Some laptops require the Battery to at least be in the laptop, whether they are good, or not.
Others will allow the laptop to run off of the AC adapter (Charger), with the Battery not installed.
Gateway Support > Gateway MD26 series of Notebook PC's > Main Support page,
Click on the - Support Documents - tab.
(Drivers / Applications / BIOS / Patches / Support Documents / etc)
Click on - Product Views - in the list.
Click on - Left View
Power connector
This is where the AC adapter (Charger) plugs in.
Examples, (Note US and Europe have different power plug ends),
[The laptop uses DC electricity. Just like the Battery it has, and flashlight batteries. DC Voltage.
The AC adapter (Charger) converts your household, or business, electricity from AC to DC.
(19 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC ]
Oct 15, 2012 | Gateway MD2614u Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
Oct 21, 2010 | Gateway MX6920 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
I have a gateway laptop model mx6454. The
Your power adapter my be loose on the motherboard which would require soldering it back on.
To confirm if this is your problem plug your laptop in and press the cord in and press the power button continuously if it powers on thats your problem.
When pressing the cord in it may take a couple of different angles before you find the right one so press it in if that don't work press it in and lean on the left, then to the right, up, down etc.
I am experiencing this problem right now I have clamped my cord for a temporary fix.
Aug 28, 2009 | Gateway MX6454 Notebook PC
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Jul 28, 2008 | Gateway M275 Tablet PC
My laptop stopped charging and i lost battery and now it wont charge at all, even tried a universal charger as well.
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
Jun 04, 2008 | Gateway MX6454 Notebook PC
Laptop is not working......adapter is plugged in and charging...???
I've seen this several times and a battery replacement fixed it every time.
Nov 08, 2007 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
