Question about Samsung Digimax V3 Digital Camera
Viewing screen failure
All photos taken come out washed out (appear overexposed) and have striping pattern accross the screen (Same as an injet printer with some failed or blocked noxxles. Does not change when flash is used or not. Does not change if used outside in bright light.
  • 188 Answers
It seems that the auto iris mechanism of your camera is not working. may be due to sticky blades or because of fault in the control circuit. you need a help of a repairer.
Posted on Oct 05, 2006
SOURCE:
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
Stripes in coloured photos
This is possibly banding and can be caused by blocked injets or a faulty printer head. It is not seen on print because the spray pattern is grossly different on text than it is on creating pictures
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Office Equipment & Supplies
PLEASE EXPLAIN WHY LINES APPEAR ON VIEWING SCREEN AND ALSO ON SAVED PHOTOS. MANY THANKS. IS IT POSSIBLE THAT I MIGHT HAVE PRESSED A WRONG BUTTON?
Lines appear on your photo's because the shutter is either stuck or is not firing completely over the lens when you take a shot. You will either get overexposed pictures (white out) or these lines like it is taken through a blind.
The most common cause for this is moisture residue building up on the shutter leafs over a period of time.
An easy way to verify this is to use the video function. It should be perfectly fine as this function does not use the shutter. This will also eliminate the sensor as the cause of the problem.
Jan 11, 2010 | Fuji FinePix F470 Digital Camera
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Images fine inside but outside natural light images overexposed
CCD is going for Failure !
it starts like this first indoor ok and outdoor over exposed then
indoor pics also when u see them closely turns pink or green in shades then horizontal vert lines appear then completely blank
just check with casio if they have issued service advisory for the CCD failure problem as all others have issued they will do it free of charge
see link
http://www.imaging-resource.com/badccds.html
Apr 11, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio EX-Z60 camera - photos are whitened or brightened
If you enlarge the picture you have just taken, is there same lines running accross the picture?
If so, the shutter magnets are causing interferance and causing the picture to overexpose and have tiny lines running through it.
In Australia the complete lens will need to be replaced as the shutter does not come seperate and this is very expensive.
Sorry for the bad news.
Oct 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
All Photos overexposed
try to check and clean the lens of your camera...
Aug 05, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Samsung Digimax V3 Digital Camera Logo
76 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
