Question about Tappan MDB531RF Dishwasher
Installed new dishwasher
Just installed new dishwasher (tappen rotory dial) ...all water is on...power ok etc. Ran hot water in sink. Machine comes on and a little water comes out at first but it does not fill. (already checked filter). Is this a delay action by the thermostat at the fill pipe? How long before the water should come out and fill the bottom of the machine?
  • beatstherest Nov 04, 2008
    water line is good (brand new) ...even bleed it to make sure. Wires prongs are tight at valve. What is the electrical part on the valve that your talking about?
  • Anonymous Dec 18, 2008
    i have the same problem what did you do to fix problem
    President:
  • Tappan Master
  • 2,651 Answers
Definitely no delay in fill, i would recheck the water line make sure not kinked, also check wires leading to the valve for good contact to valve body
Posted on Nov 04, 2008
Water not heating
Dish washers only use water supplied from the hot water side of the pipes under the cabinet or sink, so if you installed the dishwasher yourself, be sure that you ran your inlet water line and connected it to the hot water side, and not the cold water side. The dish washer has heating elements inside the machine to dry the dishes, not heat the water. If this is hooked up correctly and you are still getting cold water to heat the dishes, the problem may be that the unit is too far from the hot water tank. In that case, you may need an auxiliary hot water tank installed near the dishwasher under the cabinet. They make small tanks for such purposes.
Dec 14, 2014 | Dishwashers
Hot water doesn't work
Does any water come out of the faucet when turned to hot? If not, you may have disconnected the fautet line from the valve and attached the dishwasher line. You can check this by looking under the sink and making sure all lines are connected to valves.
If everything is connected, you may have dislodged some mineral buildup and it is blocking your hot water line to the faucet. You'll have to remove the line and clean it out.
Mar 02, 2014 | Home
Machine runs but doesn't allow water to come into machine
Don't know the history of your machine, sounds like possibly the hot water supply valve under your sink is turned off. To check this go under your kitchen sink and inspect water supply valves, (right side cold water) left side hot water valve feeds the machine. Vertical water line is for sink above, there should be a second water line coming off this valve that has its own on/off knob. Make sure this knob is turned on, (counterclockwise)if not sure turn it to the right (clockwise)till stops, then to the left till it stops. This allows hot water to enter dish machine. If valve is on and line is ok, there might be a kink in the line behind the dish machine or a restriction (clog) in the water line. May need to unplug machine and unsecure it to pull it out for inspection. Good luck,best regards.
Feb 10, 2011 | Maytag Dishwasher
I am getting an IE error on my control panel. It seems to start ok but once it starts to fill with water the IE error comes up and the machine shuts off. How can I fix this?
You do not list the manufacturer and model number, but it sounds like you own an LG dishwasher.
The IE error indicates that the water is not entering the dishwasher or it is entering too slowly / with little pressure. It is important to check the water inlet pipe (hot water connection under the sink) all the way to the dishwasher. Check for any kinks/blockages after you confirm that the valve at the sink is fully open.
Please report back here with what you find. If you still have problems, there are other things to check, including the solenoid valve just past the connection of the water inlet.
Aug 03, 2009 | LG Dishwashers
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Solution for Thermado DW245ub dishwasher
You don't have enough hot water coming into the didhwasher. The element is coming on to heat the water. Are you using the sanitizing cycle? Vitally
May 13, 2009 | Thermador DWU244 Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
No water entering machine - mains supply OK
On a Whirlpool ADP4731 dishwasher, try this...
Double check that the under-sink valve is open, providing hot water to the dishwasher.
If it is, the water inlet valve should be checked for proper operation.
The F4 error code means "drainage fault" which should be checked after the water inlet problem has been resolved.
Good Luck!
Apr 08, 2009 | Dishwashers
Plumber fixed the sink, now dishwasher is broken
sounds like the water is off, too coincedantal to brek after the plumber is there, the hot water under the sink is where the water supply to d/w is. obviously youre hot water at sink is working, there shloud be a sperate on/off valve for the d/w somewhere nearby
Mar 07, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Dishwashers Logo
116 people viewed this question
Top Tappan Dishwashers Experts
marley mcelhinney
Ronald Rissel
Melissa Martin
Melissa Martin
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
