Question about Epson Stylus C84 InkJet Printer
Won't print click print and blank paper comes out. I checked the trouble shooting and looked under printers on the control panel. The C84 is listed as idle. How to I change it from idle?
  • 1 more comment
  • Anonymous May 16, 2009
    I have the same problem i cahnged the ink and now it wont print
  • Anonymous May 20, 2009
    I also have the same problem. The ink cartriges show high levels. Black is new but when I use print, it moves as if its printing but the page is blank. I've used the clean printer jets and only a light blue line appeared.
    ow do you unclog the head?
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi freddiehanmo - I am sorry that you have had no response for so long.
    If you still have this problem, please post a new comment and I will
    help you with it.
CoachTim
  • 202 Answers
SOURCE: Printer will not print
Lacy, Other than obvious, Do you have ink?...Have you tried running the nozzle cleaner from with print properties? Has your ink maybe dried up. Try to reset the ink cartridge(s)..look at the bottom of the cartridge and see if the ink looks fresh(wet) or is it dry? Have you tried printing from more than one program? You can find other info here and download new drivers if need be. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=41662&prodoid=46048264&category=Products Good Luck, Tim
Posted on Feb 04, 2007
svenby
  • 66 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
your printer is clogged and i think it is impossible to unclog. you can try to use the flllowing link( unclog solution) cost 10 usd!!
good luck http://www.fixyourownprinter.com/kits/epson/K89
Posted on May 09, 2008
  • 191 Answers
SOURCE: Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Posted on Oct 05, 2008
SOURCE: printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Posted on Feb 16, 2009
d2704
  • 101 Answers
SOURCE: epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Posted on Mar 06, 2009
Printer won't print - Acts like it is printing but come out blank.
I assume you have good full ink cartridges in the machine.
Go to your printer set up by clicking on START in the lower right hand corner of your screen then click CONTROL PANEL then look for printers - may be under DEVICES AND PRINTERS. Then make sure the correct printer is online in the drop down menu. Look around the choices after that and see if the test page will print properly. Good luck. Pete
Jul 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Printer working but now printing onto the paper
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck in there.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I cannot print anything from my printer it prints blank pages how do i troubleshoot
Click Start
Click Control Panel
Click Printers
Click with the SECOND (usually the RIGHT) mouse-button on the icon for your printer.
Click Properties
Click "Print Test Page"
If it prints a "blank" page, then either your printer is broken, or it is out of ink.
Take the printer to a qualified technician for trouble-shooting.
Nov 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
Flashing left light under x and not printing
One of your ink cartridges is empty
or you may have paper jam
Check for a jam first.
Then go and find your printer folder. I don;t know hwich Op sys you are using, but try
control panel>printers and faxes>
>right click on your printer>
click on preferences and then there is a category for light information.
I hope this helps. Good luck to you.
Aug 15, 2008 | HP Deskjet 6940 InkJet Printer
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing blank pages
Check out the online guide and trouble shooting for a solution
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Stylus CX6600 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Nov 30, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Not printing well in black ink.
Click this Link
Choose Stylus CX5400 on the webpage
Under Select an OS
I hope this helps
Nov 11, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
