Question about Kenmore 24032\24036 Top Load Washer
Kenmore dryer 70 series will not start after spark
I was replacing the belt which had broken and upon belt replacement I plugged the machine in to check operational status and everything was fine. I then forgot to unplug the unit and began placing the covers back on. When I was placing the exhaust cover back on, I saw a spark and I quickly unplugged the unit. Now the unit will not start.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like you shorted out somthing id look to see where the spark occured and chances are that a thermostat what shorted out.
Posted on Nov 04, 2008
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
70 series how to replace belt
the kenmore 70 series do not come with belts they have a coupler behind the motor. Fairly easy to replace you can actually find videos on youtube.com to walk you through how to change it.
Oct 02, 2009 | Kenmore Washing Machines
I have a Kenmore 70 series Electric dryer, the Dryer Heats up, but it does not tumbel
Your belt is broken or off. Watch the video for help replacing it
Jul 07, 2009 | Kenmore 63942 Dryer
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
on the panel that you were putting on check to see if there is a burn mark. then check the wire that you hit. fix any broken wires. and also check your fuses or circuit breakers.
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
