Question about Dell E173FP 17" LCD Monitor
Dell E172FPb screen blinking
Hi there, my dell E172FPb come on try to show the screen and then turns of again try to show the screen and goes off, power button comes on and off.
i have checked the cables i have checked the PC everything else is fine, i can change any part from the circuit borad if i know which one is faulty.can you help me?
  • 1 more comment
  • a2z_isme Nov 04, 2008
    i can also provide pictures of the circuit board if some1 can help out by having a look. thanx
  • a2z_isme Nov 08, 2008
    yeah i know there is some faulty component on the inverter board but i dont know which one is it. if some1 can help me with that, itwould be great. thanx
  • jeff928 Nov 13, 2008
    I've exactly the same proble as posted by a2z_isme on Nov 04, 2008. Screen comes on for second then switches off. How do i get the back of the LCD screen off to get to the capacitor / circuit board without distroying the casing? Any particular trick / knack? i've tried, but it's a stubborn little bugga.
    Problem Solver:
  • 8 Answers
If you've tested turning the monitor on without the VGA cable and it's still blinking I'd say there's a problem with one of the capacitors on the power supply card on your screen, when you're able to check it would you mind telling me the brand / reference of it ?
Posted on Nov 07, 2008
The power light on our model E172FPb Dell monitor is blinking. The screen does not turn on. What could be the problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 19, 2010 | Computers & Internet
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc:
Jan 30, 2010 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at:
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
E172fpb monitor that turns on, but then goes dim
Your display have an inverter driver broken, So the back light can't turn on. Here is a website that shows this issue:
Feb 14, 2009 | Dell E173FP 17" LCD Monitor
Dell flat screen
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell 1703ft (17" UltraSharp LCD) powers on, but no picture
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this and see if it helps. All too often it is these Electro's.. GL.
May 19, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
468 people viewed this question
Alun Cox
