Question about D-Link AirPlus DI-524 Wireless Router
Dlink problem all of my lights on the dlink lights up accept the WLAN and status
  • D-Link Master
  • 6,487 Answers
If those light are all lit up and WLAN is OFF there's a big possibility that the device is getting bad, first thing to do here is to reset it , to reset the unit Press and hold the reset button for 30 seconds using a pen for about 30 seconds while the power is ON, then after that release the reset button and unplug the power of the router for 10 seconds and hopefully after that the lights should be back to normal but if not you may need to contact Dlink or get a new router instead...
Posted on Nov 04, 2008
DLink WBR-2310 freezes up with all four of the LAN ports lighted up along with the WAN LED and the power LED....the status LED and the WLAN LED are not on....router is just frozen and reset button does not...
If all lights are lit regardless of anything connected then you may have a hardware failure. Try a hard reset by putting a tip of a paperclip into the small reset hole while powered on for 10 seconds. See if that resets you router - if not then it is dead.
Nov 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Should the status light be blinking?
you should call the wireless manager.
good luck.
Jul 26, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Hi, I have a dlink DSL-G604T router, wlan light not on.
Hello there!
Only thing that can cause your wlan light not working consistantly or with some blinks (which is normal thing) is bad lan cable which leads from your ADSL modem to your wlan entrance on your wireless router, please check that cable in order to fix that problem. Cable doesnt need to be coaxial so it can have 2 different lan sets (2 poles of exits male and female exit). Thats it ! =)
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 15, 2010 | Computers & Internet
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
Dec 01, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
Dec 29, 2007 | D-Link DI-624M Router (DI624MRE)
AT & T Hook up to D-Link
If those lights are lit, they often have a "Code" this code is in the manual. Please find below a link for the manual I am sure all will be found in it. ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf Oh & I am sure ya can connect another WiFi'ed PC no prob's.
Sep 15, 2007 | D-Link AirPlus DI-524 Wireless Router
Router not working, help please!
You may may need to configure your D-Link to use your type of internet! Try following the Quick Install Guide which can be found here: ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip The WLAN light doesn't come on probably because you have the wireless disabled, which can be re-enabled once in the configuration for the wireless(in the document mentioned above) If you are having any difficulty following the guide or have folloed the guid and still can't connect, please get back to me regards, babb
May 14, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
477 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
